Southern California Area Southern California Members.
I'm getting really frustrated!
Old Jul 16, 2002 | 12:16 AM
Dwayne88IROC's Avatar
Car: Cars
Engine: SB
Transmission: manual
Axle/Gears: 9bolt
I've been trying to link to my ECU for a long time now and today I finally thought I would get Diacom to work on my 88 IROC.
I've done all the cbls and freeware.
I found a big problem with my lap top parallel port and got that fixed today. I tested the lap top on my parents 91 caprice and it worked perfect right from the get go but when I tried it on my 88 it wouldn't link in ALDL mode only Diagnostic mode. It linked up after waiting about 30 seconds and it was giving me data. YEAH! I turned the car off and exited Diacom for some dinner. When I went back and did the same thing the car barely ran and after a minute I could no longer stand the rich fumes. I turned off the ignition then I noticed that there was a crapload of error codes the first was a 51-faulty or improperly installed eprom.
Here are some of the others.
45 - rich exhaust
54 FP - voltage malfunction
23, 22,15,14,13,12 WTF?? Can the car even run with all those codes.
I removed the cable and started the car and it ran ok again but was really rich and the RPMs fluctuated between 500 and 1500 for about 2 minutes. Then it idled around 750 and 800 and was back to the same old ok tune. The SES light never stayed on but with Diacom linked it was flashing like I needed the fire extinguisher agian.
I did remember seeing a bunch of data like 48 knock counts and my TPS at idle was .70 a little too high. So in that moment of data reading I did retain some useful info but DAMN.
Linking to the ECU is only the first part of getting this car tuned.
I hope thats the hardest part to this EFI tuning.
Tomorrows another day and I'm hoping for more motivation then.
Old Jul 16, 2002 | 02:22 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Diagnostic Mode puts the car into limp-home mode, as if you'd put a paperclip in the ALDL. I wouldnt run it like that. Have you looked at your ALDL connector? Do you have an orange wire in Pin E or Pin M? If its in Pin E only, then connect a jumper to Pin M, or just try removing Pin E and putting it in Pin M.
Old Jul 16, 2002 | 10:08 AM
Car: Cars
Engine: SB
Axle/Gears: 9bolt
Well that explains why it ran so bad. I doubt if I would have been able to "limp home" in that mode. It ran BAD.
I have Nate's HPP adapter now and it works great in the 91 Caprice.
Old Jul 17, 2002 | 11:54 PM
BLWR PWR's Avatar
Car: 89 IROC
Engine: Built 383, Vortech SC
Transmission: Pro-Built 700R4
Axle/Gears: Dana 44, True Trac, 3.54
All that rompin,stompin horsepower waiting to be unleashed on the quiet, sleepy little hamlet known as Lost Almost, oh, I mean Los Alamos. Just a matter of time till you're burnin em from the Chevron to the big hotel!!
Old Jul 18, 2002 | 01:13 AM
james_85Z28's Avatar
Car: 2003 Porsche C4S
Engine: 3.6L
Transmission: 6-speed Manual
did you try the datamaster software for the 165? It works in windows 98 great. I've never had a problem linking up. But it has disconnect a couple times. So if that doesn't link up then something is definitely wrong with either the cable or laptop.
http://www.ttspowersystems.com/dm_dload.htm
The beta is at the bottom of the page. It has 20 free runs.
gta892000
Aug 11, 2019 11:16 AM
1992CamaroGirl
Dec 25, 2017 08:45 PM
RedLeader289
Sep 23, 2015 06:50 AM
Hawkeye1980
Aug 31, 2015 07:09 AM
