Southern California Area Southern California Members.
difference in starters say 89 manual and 1992
Old Jan 24, 2003 | 08:34 PM
james_85Z28's Avatar
Car: 2003 Porsche C4S
Engine: 3.6L
Transmission: 6-speed Manual
what's the difference between a starter for an 89 manual equipped V8 (TPI, LB9) and a 1992 TPI? size, solenoid placement?
(It appears the manual and auto tranny 1992 TPI received the same starter)
Old Jan 24, 2003 | 08:52 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
I believe the manual trans cars use a smaller flywheel than the auto trans cars — 153 tooth vs. 168 tooth.
If you buy a high torque mini-starter it will work with either trans. They come with two sets of mounting holes to accomodate both flywheels.
Old Jan 25, 2003 | 12:40 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Naw 168 tooth was used in big blocks. All thirdgens have 153 tooth flywheels/flexplates. The starter difference is just because of the different bellhousing on the auto vs manual.
Old Jan 25, 2003 | 01:25 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
In my case, the auto starter had a larger diameter than the manual starter. Don't forget that the starter mounting bolts are shorter for the manual starter also.
Lon
Vintageracer
Jan 10, 2020 05:33 PM
1992CamaroGirl
Dec 25, 2017 08:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
