For People who have cut-outs, need advice
If I run cut-outs before my catlyic. Will this give me any problems with the comp or give me codes. Its a 92 GTA w/ 350 eng, dual cat, air system.
Thanx,
Psycho:lala:
Thanx,
Psycho:lala:
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
Cut-outs basically bypass your muffler or rest of the exhaust system. If you put one in front of the cat then when it is uncapped it is basically running open headers. It is a piece of tubing coming off your exhaust tubing that can be opened to allow exhaust to go out through it or closed to let the exhaust go back through the regualr exhaust.
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
yeah, they basically bypass your exhaust system...mine was installed in the "I" pipe almost under the passenger seat (dual cats have been removed) you can also get electronic valves to adjust the volume from inside your car...I have a McCord Power Plate on my cutout and I love it....sounds like a NASCAR when I want it that loud...or I can have it flowmaster loud...best of both worlds...
Re: For People who have cut-outs, need advice
Thanx,
Psycho:lala:
Thanx,
Psycho:lala:
