extrem power loss
Car: 91 firebird now
Transmission: 5 speed
extrem power loss
Ok I found a coolant leak on her today by the intake on the pass side and now she has lost pretty much all power she won't do over 20 mph, did I blow a head gasket? anyone near El cajon that could help me out?
Originally posted by CustomX
does it smoke? revabiltiy?
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Power loss
Most likely a plugged cat. Have someone rev the engine while you hold your hand at the tail pipe outlet to see if you have a good strong flow of exhaust.
Re: Power loss
I saw it today when I was changing the oil right by the engine cradle its crushed it about half an inch wide, what am I gona do?! But it was being slow at passing before it got crushed, so maybe its the cat as well, and now the intake gasket is leaking for sure. Lots of white smoke out of the exhaust but its not in the crank case yet.
replace the gasket and buy some cats and have a shop do up a new set of pipes where thier crushed.
theshackle
Sep 17, 2020 08:26 AM
sailtexas186548
Aug 24, 2015 10:11 PM
