Southern California Area Southern California Members.
Pick a part run tomorrow
Old May 24, 2003 | 12:01 AM
Jstcrzyengh's Avatar
Car: 1988 Camaro Convertible
Engine: 355
Just wanted to see if anyone else was going out tomorrow or wanted to go. Me and my buddy are heading over to the one in Long beach or Stanton need some parts for the camaro.
Well be in the 92 Purple haze RS, will check my email before I go.
James
Old May 24, 2003 | 01:01 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
I'll be busy building parts for stock. While there look for the trunk release button for a late 70's Caprice for your car. It is a yellow button surrounded by a black metal tag labeled "trunk release" located in the glove box. I'll show you where I installed it on mine to pop the trunk.
Lon
Old May 24, 2003 | 01:10 AM
Engine: 355
I was actually going to ask you about that. I was thinking I could put a trunk pop in my car. Doesnt the key essentially act as the A/B switch to complete the circuit? I was thinking that you could basically run the same thing and run it into the cabin and have the same kind of switch as the tonneau switch to complete the circuit. Sound about right? I will look for one while I am there tomorrow. Need anything from there?
James
Old May 24, 2003 | 01:13 AM
lonsal's Avatar
Always need 36mm front sway bars and 24mm rear. But you've GOT to take a caliper to measure it to be sure. I've been fooled by crud on it a couple of times and wound up with a 34mm or 23mm after it came back from sand blasting and powder-coat.
Lon
Old May 24, 2003 | 02:15 AM
Engine: 355
I will look for you. What about the wonderbar's?
James
Old May 24, 2003 | 08:13 AM
lonsal's Avatar
If you find one on a 36mm sway bar grab both, or add one to the 36mm bar (if you find any). They don't charge extra for the WB that way. Otherwise I'll decline on the WB's alone. I have plenty of my version.
Thanks,
Lon
Old May 24, 2003 | 12:27 PM
Engine: 355
Oh you make your own? I thought you modified the GM one's. Well, ill just leave them there than, because I planned on picking up a powerdercoated one from you anyway, but if I find the sway bars will definetly pick them up.
Old May 24, 2003 | 08:04 PM
Ruddigger's Avatar
I'd go, (I need a new driver's side door, maybe fender,) but I'm gonna be... Umm... Busy... With my fiancee...
We're going to be uh, knitting... Yeah! Yeah, knitting, knitting and maybe baking!
Oh well, maybe next time.
Old May 24, 2003 | 08:09 PM
Engine: 355
Didn't end up going, it was raining, pick a part was PACKED, guess its free admission and 20% off parts this weekend. Plus I needed to head over to my buddy's house with some of my parts.
Steven 86IROC-Z
Mar 28, 2026 06:42 PM
Terrell351
Jun 13, 2021 01:13 PM
camaro71633
Sep 1, 2015 10:24 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
1nastygta
Aug 8, 2015 07:38 PM
