Southern California Area Southern California Members.
Remote prom holder done.
Old Jul 9, 2003 | 01:12 AM
JERRYWHO's Avatar
With all the time the ecu was on the floor it was time to make a change.
Jerry
Old Jul 9, 2003 | 11:53 AM
8T8IROC's Avatar
Car: Moving...
Engine: Running...
Transmission: Shifting...
Very cool as always Jerry :hail:
Old Jul 10, 2003 | 01:49 AM
james_85Z28's Avatar
Car: 2003 Porsche C4S
Engine: 3.6L
Transmission: 6-speed Manual
very cool. Any abnormalities with signal interference? where do you plan to place the remote PROM connector or is it going to be located on the ECM case?
Old Jul 10, 2003 | 11:13 AM
JERRYWHO's Avatar
Yes, If the cable is over 12" long the ECU will not see the chip and if the cable is over 10.5" long you will get some S.E.S. lights
The prom is mounted on the bottom of the case so you can just change the prom without pulling down the ECM. The prom in this location has a cable thats 5" long and has tested with no problems.
Jerry
Old Jul 10, 2003 | 11:36 AM
JERRYWHO's Avatar
James
Looking at the ECM and you have me thinking about more EMI protection I will mill a slot in the case and try to run the cable on the inside so only the zif is external.
Jerry
Old Jul 10, 2003 | 05:47 PM
BrandenCali's Avatar
I thought
You were making this for 2 proms I thought I seen a ecm before with a dual stage chip for Nos??
Linson
Oct 24, 2025 02:00 PM
Fanatic1074
Oct 3, 2022 05:57 AM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
dusterbd
Sep 29, 2015 08:40 AM
gta892000
Sep 16, 2015 12:37 AM
