Southern California Area Southern California Members.
In car adjustable Koni rear shocks
Old Oct 4, 2003 | 12:21 AM
JERRYWHO's Avatar
What do you think.
Jerry
Old Oct 4, 2003 | 12:22 AM
JERRYWHO's Avatar
One more
Old Oct 4, 2003 | 08:34 AM
james_85Z28's Avatar
Car: 2003 Porsche C4S
Engine: 3.6L
Transmission: 6-speed Manual
what is different about them vs. a normal installation? (sorry, I have no reference as to how they are normally installed).
Old Oct 4, 2003 | 11:50 AM
Dwayne88IROC's Avatar
Car: Cars
Engine: SB
Transmission: manual
Axle/Gears: 9bolt
Jerry are you going to make it tonight? I gotta see your ride.
Old Oct 4, 2003 | 06:24 PM
formula91's Avatar
Car: 92 GTA
Engine: Yes
Transmission: Busted
The rear ones have to be removed to be adjusted. I guess he figured out a way to adjust them without removing them.
Old Oct 4, 2003 | 10:23 PM
JERRYWHO's Avatar
The Koni SPA-1 drag shocks for a third gens are single adjustable and you have to unbolt the lower shock bolt and compress the shock than twist it to change the setting.
I had a set of double adjustable SPA-1 shocks for an old race car with bearings on each end and was going to cut the top bearing off and weld a stud on it. with this the rebound adjustment will be very hard to use. ( see picture )
Old Oct 4, 2003 | 10:26 PM
JERRYWHO's Avatar
My cure for this was make a new 4340 shock end.
Jerry
Old Oct 5, 2003 | 08:38 PM
Engine: 3.6L
do the koni sports (yellows) need to be unbolted to be adjusted or is it hust your drag Konis?
Old Oct 5, 2003 | 08:54 PM
JERRYWHO's Avatar
Don't know never had them.
Jerry
Old Oct 5, 2003 | 10:22 PM
bluethunder28's Avatar
Yes and no.
The old style require you to unbolt. he 4th or T-birds are on the top side.
Old Oct 5, 2003 | 11:11 PM
Engine: 3.6L
so the Konis yellows for 3rd gens have an external adjustment only?
Old Oct 6, 2003 | 01:48 AM
The 3rd gens have to be unbolted. That's why we started in using the T-bird shocks. A little softer and you can adjust them without unbolting them. About mid away thru 4th gen, a new Koni man came on board and started making the Koni's externaly (in car) adjustable.
Old Oct 6, 2003 | 07:42 AM
Engine: 3.6L
what do you mean 4th gen camaro? So I should order the rear shocks for a T-bird or a 4th gen Camaro? what year T-bird?
Thanks,
James
Old Oct 6, 2003 | 07:36 PM
Engine: 3.6L
ttt
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Exxon Limited
Aug 9, 2015 08:13 PM
1992 Trans Am
Aug 9, 2015 04:32 PM
