Southern California Area Southern California Members.
What does it take to perform an engine swap??
Old Feb 22, 2004 | 02:29 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
I currently own a 91 Camaro with 305 TBI and want to swap for a 350 TPI. I want to buy the engine used with all ducting wiring and computer and have the engine rebuilt. How wild can I go with the rebuild and still keep it Cali smog legal?? Also after I change the motor I will have to take it to a Referee station for approval correct?? I know the general rule is the motor change must be a same year or newer and can't pollute more than the original motor did. Won't a 350 tpi pollute more than a smaller 305 TBI??
Old Feb 22, 2004 | 06:17 PM
Parrydise7's Avatar
Give Dyno Don a call. He can answer all that. IIRC, you won't need to go to a referee station.
Old Feb 22, 2004 | 08:07 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
who is dyno don and why don't I need to go to a referee station??
Old Feb 22, 2004 | 08:14 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
My info is in the Friendly Companies list.
camaro's came with "350's" so it's legal to swap without going to the referee. I did mine ...no problems.
Old Feb 22, 2004 | 09:14 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
You are making as much HP as the LS1 engines but more torque.
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
