Southern California Area Southern California Members.
TPI parts needed
Old May 3, 2004 | 10:12 AM
gmendoza's Avatar
TPI parts needed
I need some TPI parts; one is the distributor cover, the one that bolts on to the plenum. Also my runners have a thin coat of gray paint so they are a great candidate for polishing but I don’t want a polished TPI, I want a stock appearance. Maybe someone that has an extra set of original runners and had the intent of polishing them will be interested in trading for my runners.
PS: I am also open to other possibilities.
Old May 6, 2004 | 09:15 AM
gmendoza's Avatar
Well I just got my runners sandblasted to remove the paint and they look great. So now all I need is the cover for the distributor that goes on the plenum. Anybody have one?
Old May 6, 2004 | 09:23 AM
gmendoza's Avatar
double post
Old May 6, 2004 | 09:25 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Try doing a search on the TPI board for the GM part number. I dont know if its still available but there is a plastic distributor cover for f-bodies and an aluminum one for Corvettes. Last check they were $25 or so.
Old May 6, 2004 | 12:07 PM
8T8IROC's Avatar
Car: Moving...
Engine: Running...
Transmission: Shifting...
And in addition to Kevin's suggestion, if you are willing to purchase one you may want to consider Accel's Plenum Extension which is priced at $19.99 on Jegs & $18.95 on Summit Part Number: ACC-140006
Old May 6, 2004 | 02:19 PM
gmendoza's Avatar
I took Kevin's advice and did a search, I came across a post with part number and link to GMpartsdirect. So I ordered it there. Total came out to $21.98.
Old May 7, 2004 | 01:09 AM
Kevin91Z's Avatar
The Accel plenum extension is a partial piece that does not cover the distributor. Its made to fit their distributor.
http://www.jegs.com/cgi-bin/ncommerc...15&prmenbr=361
midge54
Jan 29, 2017 07:00 PM
IROCZ1989
Jan 24, 2016 03:55 PM
beachrodder
Aug 25, 2015 08:05 AM
1nastygta
Aug 8, 2015 07:38 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
