Southern California Area Southern California Members.
Plenum gaskets
Old Sep 27, 2004 | 10:54 AM
drop-top IROC's Avatar
Engine: 305 TPI (LB9)
Transmission: WC T-5
Plenum gaskets
Are these still readily available? I think I remember a post some time back about the TB gasket to the plenum no longer being available. I'll be needing the gaskets between the runners and the plenum. Does anyone know if these are available from GM or if Fel-Pro or others make the gasket? If anyone has part numbers, that would be helpful as well. Thanks! -Jerry O.
Old Sep 27, 2004 | 11:06 AM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
Re: Plenum gaskets
Jerry,
The gaskets are readily available. I have a Fel-Pro part number at home for the upper plenum kit. It includes everything from the TB gasket to new fuel injector O-rings. I can look it up tonight.
Old Sep 27, 2004 | 11:55 AM
8T8IROC's Avatar
Car: Moving...
Engine: Running...
Transmission: Shifting...
I purchased a Fel-Pro set over the counter from Auto Zone as well.
Old Sep 27, 2004 | 11:20 PM
Good to hear. R&R on the plenum shouldn't be a big deal then. If I get on it early Sat, I should have it all back together for the meeting that evening.
sheachopper
Jul 31, 2019 11:27 AM
tyeo098
Nov 30, 2015 06:27 PM
toronto formula
19
Oct 6, 2015 12:27 PM
