Southern California Area Southern California Members.
Posi ?
Old Jul 5, 2005 | 11:34 PM
blksc's Avatar
Posi ?
I posted about an 87 trans am i was trying to buy a while ago, and i'll finally be picking up the car tomorrow. Its a dream come true.
The dust caps say WS6, but the console is missing so im not sure if it actually has the WS6 suspention... I do know that it has drum brakes in the rear.
NOw to my question: Anyway to find out if i have posi without getting a 'exhibition of speed' ticket
Old Jul 5, 2005 | 11:48 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
Check for the posi code in the club box or drop the rear cover and see if your carrier looks the same as the picture below or raise the rear and spin a tire. If both tires spin, you have a posi.
Old Jul 5, 2005 | 11:50 PM
blksc's Avatar
Where is the club box ?
I will put the car up in the air when i have it delivered and see.
Old Jul 5, 2005 | 11:55 PM
86z/92rs's Avatar
Meant to type glove box and the code for posi is G80.
Old Jul 6, 2005 | 11:17 AM
blksc's Avatar
Okay im gonna sound totally dumb here..
But i thought these cars didnt have a glove box.. only the map pocket?
Old Jul 6, 2005 | 11:25 AM
8T8IROC's Avatar
Car: Moving...
Engine: Running...
Transmission: Shifting...
Glove Box = Center Console
If the RPO Code sticker is not located there, then check the storage pace located on the left hand side of the trunk.
Old Jul 6, 2005 | 11:26 AM
blksc's Avatar
Oh! i said in my first post that the center console had been removed.
I'll take a peek in the trunk
Old Jul 6, 2005 | 11:51 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
If both tires spin the same direction you have a posi. If the other tire spins the opposite direction if isn't a posi. Yes you can have a posi and rear drum brakes. That is how my '88 Firebird Formula 5.0 TPI WS6 is equipped.
Lon
Old Jul 6, 2005 | 12:04 PM
blksc's Avatar
OH okay cool. That sounds like an easy test.. especially since it needs brakes :-D
Old Jul 6, 2005 | 01:22 PM
camaro86's Avatar
Car: 91 z28
Engine: 350 tpi
is a posi good or bad?
Old Jul 6, 2005 | 02:00 PM
lonsal's Avatar
If you're a fan of traction, then a posi is good.
Lon
Old Jul 6, 2005 | 03:50 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
The "wheel spin" test isn't always reliable. Best bet is to check for the RPO code and/or ID tags on the differential cover.
If all the ID info is missing, then pull the diff. cover and do a visual check as mentioned above.
Old Jul 6, 2005 | 03:59 PM
8T8IROC's Avatar
Car: Moving...
Engine: Running...
Not to mention with the age of these cars, and usually not knowing the history of how it has been driven the rear end could be worn out a bit.
Old Jul 6, 2005 | 07:09 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
I've never heard of a posi that bad...but that test doesn't work on a Zexel
Old Jul 6, 2005 | 07:14 PM
84RIceEater's Avatar
Car: 84 Camaro. 90 integra
Engine: LG4, 1.6 (402hp)
Transmission: 700r4, JDM ITR w/ kaaz LSD
I would Just Pull The cover off and check and while your down there get a chrome cover, then replace the Gear Oil.. Then you know you that you have fresh fuild.
KO1
16
Oct 15, 2015 05:00 PM
92projectcamaro
Sep 29, 2015 07:07 PM
