Southern California Area Southern California Members.
Super Ram Intake wanted
Old Oct 22, 2005 | 06:19 PM
ULTM8Z's Avatar
So, I'm pretty well convinced I have massive distribution problems with my Miniram at low speeds. Probably going to ditch it in favor of a Super Ram.
Trying to see if anyone in the So Cal area has one to get rid of or knows someone who wants to.
Thanks.
Old Oct 23, 2005 | 10:45 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I'm guessing you cant fit a StealthRam under the hood? Perhaps you should go to a single plane EFI manifold?
Old Oct 23, 2005 | 11:53 AM
Parrydise7's Avatar
What Kevin said.
Check out some posts by Jerrywho. He put a Stealth ram on a third gen. As long as you've got room, that Stealth ram can put up some pretty impressive numbers.
For us thirdgen guys, the Super Ram is nice because it is smog legal. You don't have that concern.
Old Oct 24, 2005 | 11:05 PM
ULTM8Z's Avatar
How does the Superram stack up against the Stealth Ram?
Also have to consider the rest of my setup. Seems like a Superram would be well suited to my engine combination.
I think 400 hp is possible with a Superram, right? In which case, should be more than enough for my purposes.
Old Oct 24, 2005 | 11:15 PM
Russ-So Cal's Avatar
We have guys on this board getting close to 400 hp on modified tpi's, 400 on a Super Ram would be easy I would think.
Old Oct 24, 2005 | 11:51 PM
james_85Z28's Avatar
Car: 2003 Porsche C4S
Engine: 3.6L
Transmission: 6-speed Manual
what cam are you running? ZZ4 cam?
With your heads, super ram, and accel 219 cam you will have about 335-350 RWHP and about 390-400 RWTQ. The holley stealth ram would be a simpler installation and probably trade you 10-20 RWHP for 10-20 RWTQ all else being equal. To take advantage of the stealth ram it would be ideal to utilize a bigger cam in the 224-234 intake duration range and should be geared to match.
Old Oct 25, 2005 | 01:08 AM
Kevin91Z's Avatar
Did you check out this post?
https://www.thirdgen.org/techbb2/sho...hreadid=273727
Old Oct 25, 2005 | 04:17 AM
BrandenCali's Avatar
I don't think he is using a zz4 cam.. Comp Cams 262?
Old Oct 25, 2005 | 08:55 AM
ULTM8Z's Avatar
Very interesting post! Sounds like the Superram did very well in that test. Since the rest of my engine combo probably isn't very good past 6000 rpm, I think the Superram will suit my needs well.
Old Oct 25, 2005 | 12:24 PM
8T8IROC's Avatar
Car: Moving...
Engine: Running...
Transmission: Shifting...
I would go with the Stealth for your application, especially considering you don't have to worry about smog. The Stealth is a lot cheaper to purchase and much easier to wrench on
Old Oct 30, 2005 | 11:06 AM
Parrydise7's Avatar
The prior post makes a good point. A Super Ram has some issues related to installation that can make it a real pain.
Old Oct 30, 2005 | 01:22 PM
With all the modifications you do.. Makes it a lot easier for next time.. Having the correct tools helps things go much easier.. Don't forget to consider the Injector harness modification.. Makes things much easier if you want to pull the engine in a timely matter an complete..
Frozer!!!
Jan 19, 2024 04:55 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
bryan623
Aug 10, 2015 11:33 AM
