Southern California Area Southern California Members.
Don I need HELP
Old Dec 12, 2005 | 07:42 PM
InsaneIROC's Avatar
Car: 89 1LE IROC Z28
Engine: 364 Ci Ls2
Transmission: Mn12 T56
Axle/Gears: Borg Warner 9 Bolt With 3.70 Gears
Don I need HELP
I think my fuel pump is going out my question to you is dose it give any warning before it go's. I got my car running and sometimes it will start and sometimes it wont I was driving it Friday night and it just died on me and wouldn't start up till the next morning any ideas
Old Dec 12, 2005 | 07:46 PM
Russ-So Cal's Avatar
Does it crank and not start, or does it just not crank?
Old Dec 12, 2005 | 11:28 PM
InsaneIROC's Avatar
Engine: 364 Ci Ls2
If I go out in the morning it will start if I let it run for 15 to 20 minutes then shut it off and try to restart it will just crank and not start .
Old Dec 12, 2005 | 11:54 PM
When it runs, do you get a high load miss?
Old Dec 13, 2005 | 01:00 AM
InsaneIROC's Avatar
Engine: 364 Ci Ls2
Yes I get a really nasty miss.
Old Dec 13, 2005 | 03:19 AM
Mikos_89's Avatar
Car: '89 GTA, '15 Camaro LS 6sp.
Engine: L98, LFX.
Transmission: 4L60, AY6.
Axle/Gears: 3.27's.
Is it the original fuel pump?
Old Dec 13, 2005 | 07:02 AM
InsaneIROC's Avatar
Engine: 364 Ci Ls2
Yea its the original
Old Dec 13, 2005 | 12:46 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Also you might want to check your fuel filter. It is cheaper to replace than the fuel pump.
Old Dec 13, 2005 | 01:32 PM
james_85Z28's Avatar
Car: 2003 Porsche C4S
Engine: 3.6L
Transmission: 6-speed Manual
replace the fuel pump relay.
Old Dec 13, 2005 | 02:04 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Transmission: Tremic6060
Axle/Gears: good enough
Replace the car j/k
If it is the orginal fuel pump, i would replace it soon anyways... who knows.. it could cut out on you on the high way, late at night, with no one around. Better safe then sorry i would say.. but it all depends on money... just like everything else in this world
Old Dec 13, 2005 | 04:07 PM
High Geared's Avatar
Car: 1988 Iroc-Z
Same thing happened to me. Except It died in parking lot.....then I had to call a tow truck. Drop the axle, drop the tank, then get rid of the old pump. It sucks having to call a tow truck.
Old Dec 13, 2005 | 05:55 PM
8T8IROC's Avatar
Car: Moving...
Engine: Running...
Transmission: Shifting...
How about all the spark goodies, cap, rotor, spark module, electronic spark module, plugs, along with all the fuel stuff. I would look at the easiest/cheapest to replace, along with those that have been on the car the longest without being replaced
Old Dec 13, 2005 | 06:51 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
You need to run a few tests before you start throwing parts at it.
Old Dec 13, 2005 | 07:10 PM
InsaneIROC's Avatar
Engine: 364 Ci Ls2
Ok the cap and rotor are new as are the wires and plugs when it dose this I still get spark. The fuel pump go's on when I turn on the key I also have 49 psi at the fuel rail. So him lost going to go down to Power Chevy Stray and buy all new relays and sensors. I ordered a new distributor form Summit it should be here in a couple of days. I also used my dads snap-on scanner and I have no code's present.
Old Dec 13, 2005 | 08:08 PM
InsaneIROC's Avatar
Engine: 364 Ci Ls2
I just checked the injectors with a stethoscope and all 8 are working.
Old Dec 14, 2005 | 05:41 AM
Mikos_89's Avatar
Engine: L98, LFX.
Axle/Gears: 3.27's.
Have you replaced the ignition module recently? Most autoparts places should have a way to test them. However, I'd get a new one anyway along with a new pickup coil as well.
As for the fuel pump, I think that's your trouble right there. My uncle's '91 Z28 had a few intermittent no-starts until finally it konked out on him at a Denny's parking lot.
Talk about fun! We had to do the fuel pump R&R right there in the parking stall at his apartment complex between two other cars at night. To make matters worse, a noisy security guard (doing his rounds) kept coming by looking at what we were doing. When I finally got the old pump out, I was waiting for the guard to come over and say: "Oh...I'm sorry, but I can't let you guys work on cars here!". Fortunately, he let us finish the job without saying anything.
Old Dec 14, 2005 | 10:32 AM
sixtyV6's Avatar
Just don't put the same replacement pump back in it. The factory pump has plastic intenal gears. I went to an fatory Delco '89 Vette pump for mine since it is designed more heavy duty with all metal internals and will last much longer.
Old Dec 14, 2005 | 02:37 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
Personally, I'd start with the ignition module. It's cheap to replace and it quite often is the culprit for the symptoms you describe.
Old Dec 14, 2005 | 04:33 PM
BrandenCali's Avatar
New distributor on the way yeah replace the module.. With an Ac Delco of course..
But there could be some fuel problems but who knows.. Like Don mentioned some further testing would be best to do..
Old Dec 16, 2005 | 07:07 PM
InsaneIROC's Avatar
Engine: 364 Ci Ls2
I got it it's the fuel pump had air in the fuel rail
Old Dec 17, 2005 | 10:55 AM
Good Job..
Old Dec 18, 2005 | 12:39 AM
BadAssIROC's Avatar
Car: 86 IROC
Engine: 355 TPI
Transmission: 700R4 w Trans GO shift kit
I told you that's what it was
LT1Formula
20
Nov 14, 2015 12:02 AM
db057
Sep 4, 2015 07:57 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
theshackle
Aug 23, 2015 03:49 PM
