Southern California Area Southern California Members.
350 TPI!!!!!!!!!!!!!
Old Sep 26, 2006 | 03:24 PM
Psycho_91Camaro's Avatar
Car: 1991 Camaro RS
Engine: THE LT1 SWAP SHALL BEGIN!!!!
Transmission: 700 R4
Axle/Gears: LSD! =(
Just came back from the junkyard in Wilmington,ca I went to Pick your Parts, I found a late 80s IROC Z 350 TPI, the engine is still intact and looks real good!!!!!!! don't bother taking the gauge cluster, it's in my garage ready for EBAY! =) im just giving the heads up on a UNTOUCHED 350 TPI in a WHITE IROC Z!! this is the big pick your parts!!!!!! it still has the wire harness and EVERYTHING ELSE! I shut the hood so no one else will look at it! so GO GO GO!!!! before someone takes it!
Old Sep 26, 2006 | 07:11 PM
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
ahh actually that IROC Z is a 88 I think, I got the guage cluster from a 90 350 TPI...... that engine is gone.. but the white IROC-Z 88 350 TPI is still there
Old Sep 26, 2006 | 10:31 PM
BadAssIROC's Avatar
Car: 86 IROC
Engine: 355 TPI
Transmission: 700R4 w Trans GO shift kit
Old Sep 26, 2006 | 10:46 PM
InsaneIROC's Avatar
Car: 89 1LE IROC Z28
Engine: 364 Ci Ls2
Transmission: Mn12 T56
Axle/Gears: Borg Warner 9 Bolt With 3.70 Gears
350 TIP's in PAP is nothing new thay are all over the place.
Old Sep 27, 2006 | 03:24 PM
Diggler86's Avatar
Car: 86 TA
Transmission: 700R4 - 2200 stall
Axle/Gears: 3.42 posi
i rarely even see 305 tpi's. they get cannabalized too quick.
Old Sep 27, 2006 | 06:59 PM
ROCITUP's Avatar
THERE FO SHO'
Old Oct 1, 2006 | 01:19 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
I did see one a while back, late '80's Iroc, engine still had Goodwrench stickers on the valve covers, only thing missing was the throttle body, however no money no truck meant I had to leave it behind.
They're rare, but you CAN find them ... sometimes
Old Oct 1, 2006 | 01:45 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Goodwrench stickers on the valve covers means its the cheap-*** boat anchor replacement engine. Stay away.
bamaboy0323
Sep 3, 2015 06:07 AM
theurge
Aug 21, 2015 12:46 PM
Out-Cast
Aug 17, 2015 10:57 AM
Jlanz55
Aug 17, 2015 07:15 AM
bamaboy0323
Aug 15, 2015 07:20 AM
