Look what I found
Car: 89 1LE IROC Z28
Engine: 364 Ci Ls2
Transmission: Mn12 T56
Axle/Gears: Borg Warner 9 Bolt With 3.70 Gears
Look what I found
I found this at the Long Beach HIPO Swap Meet
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Look what I found
Your pics do not work because they are not valid links.
Post the links, or attach the pics to your post.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
are the First systems THAT much better than the stock TPI systems? I think the monoblade throttle body is better, but i wasnt sure about the base plate and runners.
The base flows 300cfm right out of the box. All the others...250-260.
Abubaca
Nov 5, 2016 12:22 PM
rudolphschenker
Sep 4, 2015 02:41 AM
