Southern California Area Southern California Members.
Question about Rear ends...
Old Jan 7, 2008 | 10:02 PM
drewdown84's Avatar
Car: 1987 Camaro IROC
Engine: V8 5.0L TPI
Axle/Gears: 10 Bolt
hey there... just wondering one thing...
my uncle called me last night and started asking about camaro rear ends... and i wanted to know if there is a 7.5 inch posi rear end with 21 splines... he said that they can be found off of the 82-88 V6 models... is this true? and if so how difficult are they to find? any info is welcomed...
Old Jan 8, 2008 | 10:13 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: Question about Rear ends...
No, they are all 26 untill '90
Old Jan 8, 2008 | 01:25 PM
drewdown84's Avatar
Engine: V8 5.0L TPI
Axle/Gears: 10 Bolt
my bad... i wrote the first one at work... im at home now and i see what i wrote... its 26 spline that he wanted...
so are these units able to be found easily... or am i gonna have a major search on my hands?
Old Jan 8, 2008 | 02:59 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Fairly common in junkyards.
Old Jan 8, 2008 | 03:34 PM
Guest
Guest
Posts: n/a
Yeah at a junkyard you have even a chance to pick up a better ratio if you needed it. Dont know what he has now but there always some luck finding rear ends in the junk yard. We have found 9bolts borg warner 3:45 and we have found a ford 9" also.
Old Jan 8, 2008 | 03:49 PM
drewdown84's Avatar
Engine: V8 5.0L TPI
Axle/Gears: 10 Bolt
well... he just needs the carrier... gonna mod it to put it into a ford mercur that hes messing with... right now its a right wheel fryer...
Old Jan 8, 2008 | 05:44 PM
Imadude_134's Avatar
Car: 1991 Camaro RS
Engine: L98 350 TPI
Axle/Gears: ZT LSD with 3.42 - LS1 brakes
What is the easiest way to tell what the gear ratio is if I see a car in the junk yard? Is it possible to tell w/o taking it apart?
Old Jan 8, 2008 | 06:27 PM
Guest
Guest
Posts: n/a
You can take off the cover and check the ring. You will find the ratio that way.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
redmaroz
Aug 16, 2015 11:40 PM
