Southern California Area Southern California Members.
Code 32?
Old Dec 20, 2008 | 04:54 PM
Russ-So Cal's Avatar
Code 32?
On the way back from Christmas dinner, my ses light came on. Every time I stopped, it went off, but after driving a few miles, it would come back on again. By the time I got home the car sounded like I had straight pipes on it. I finally had time to jack it up and crawl under today and to pull the code(s). The bolts mounting the intermediate pipe to the cat had fallen out accounting for the noise. I've got that fixed. I pulled a code #32. I think that is egr, but my books are packed away. If I look long enough I can find them, but am wondering if anyone here could confirm that code 32 is the egr code?
Old Dec 20, 2008 | 05:52 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: Code 32?
Yes it is 32, not enough back pressure.
Old Dec 20, 2008 | 06:16 PM
Re: Code 32?
Maybe I fixed it then. I suspect bolts falling out of the connection between the cat and the intermediate pipe would cause a BIG drop in back pressure. By the way, my fuses were all ok. I noticed that one 20 amp fuse is marked brake/haz. I presume that fuse is for the brake lights and 4 way flashers. he fuse was ok, and the 4 ways work, so I assume I have a bad brake light switch. I ordered a new one at Kragen, it is $11.00. I was surprised at the price. It is nicve to get a price of $11.00 when you expect to pay $20-$30.
Old Dec 20, 2008 | 06:37 PM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
Re: Code 32?
Russ, I will post the flow chart for code 32 later on tonight.
Old Dec 21, 2008 | 10:34 PM
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
Re: Code 32?
as promised
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
