Southern California Area Southern California Members.
after engine swap unable to start car
Old Jan 13, 2009 | 11:20 AM
z28gsxr's Avatar
Car: 91 RS Vert/98 Sierra9
Engine: 5.7/5.0
Transmission: 5spd/auto
Axle/Gears: 4th gen rear with 3.73
Any ideas? here's the link to the description of the issue that i posted in tech.
https://www.thirdgen.org/forums/tech...s-305-tbi.html
Old Jan 14, 2009 | 09:28 AM
z28gsxr's Avatar
Engine: 5.7/5.0
Re: after engine swap unable to start car
The car started. It turns out the distributor was 180 off . But now the issue is that its running extremely rich. Any ideas?
Old Jan 14, 2009 | 11:06 AM
Russ-So Cal's Avatar
How long has it been running? How long does it take for the ecm to relearn. Is it possible that with some driving the ecm will learn and lean it out? Did you make any mods when you did the rebuild?
Old Jan 14, 2009 | 11:15 AM
z28gsxr's Avatar
Engine: 5.7/5.0
thanx russ now that i think about it the prom that is in there was tuned for the l05. he had it tuned when i bought it and my guess would be thats why its runing rich
I only let the car idle in the drive way for a few minutes but I will swap out the prom tonight and take it around the block. Thanx Russ
Old Jan 15, 2009 | 10:20 AM
z28gsxr's Avatar
Engine: 5.7/5.0
I swapped in the ecm from my 89 parts car. Its also a 5spd l03 and it idled better. I put fluid in the trans then started it up and went to put it in gear and it wouldn't go in. Completely forgot about bleeding my clutch hydrolics
specialized
Jun 18, 2022 09:26 AM
theshackle
Mar 5, 2017 06:37 PM
jharrison5
Aug 19, 2015 05:53 PM
MY87LT
Aug 17, 2015 08:43 AM
92projectcamaro
Aug 6, 2015 01:20 PM
