Southern California Area Southern California Members.
Car won't start...
Old Feb 27, 2009 | 04:56 PM
bluethunder28's Avatar
Car won't start...
without holding the throttle open. Fuel pressure is 45 and holds, changed the ignition module and TPS and still no go.
Any ideas? Trying to get the car going for the autox Sunday.
Edit to add: 5.7 TPI
Old Feb 27, 2009 | 05:22 PM
Guest
Guest
Posts: n/a
Re: Car won't start...
How does it run once its started?
Old Feb 27, 2009 | 05:53 PM
As soon as I let off the throttle, it dies.
Old Feb 27, 2009 | 05:57 PM
Guest
Guest
Posts: n/a
Might be the IAC. May be dirty, clogged, or just frozen in place.
Old Feb 28, 2009 | 01:30 AM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
Broken vacuum line?
Old Mar 1, 2009 | 08:44 PM
FerrMaro's Avatar
Ive had the same problem for the past week or so! Starts and immediately dies...have to keep the throttle cracked to keep it alive. Here's the kicker, it has seemed to correct itself...? My guess is that the original IAC has become gummed up, sluggish and at times, completely unresponsive. Now, instead of dying, if you aggressively blip the throttle, the RPMS will fall and chug around 450 rpm before surging back to the appropriate idle (which I have set @ 650). I suppose I'll replace the IAC and report back. Hope that helps.
Old Mar 3, 2009 | 05:43 PM
IAC was the problem. I wasn't that long ago that I changed it. Take it off and it was really clean. Re-did the point and she fired right up.
Old Mar 4, 2009 | 08:12 AM
Russ-So Cal's Avatar
You can take the IAC apart and clean it. Unless the motor has failed, the part that gums up is just a needle valve.
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
ZsTransAm
Aug 11, 2015 07:30 PM
ryanz281988
Members Camaros
Aug 8, 2015 06:45 AM
kyle5647
Aug 7, 2015 03:08 PM
