Best ETs
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: Best ETs
Not if you have 12-13 sec. power.
I can't power shift my T-56.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Best ETs
No the T5 cant handle that abuse for long. Mine had a few problems when I was running 13's or slower. Once I hit 12's then I sheared all the teeth off third gear.
I dont power-shift. I let off the gas, push in the clutch, and shift gears all at the same time, as fast as I can.
