putting several mods what ets improvements?
Car: 89 Camaro RS
Engine: 5.0 tbi
Transmission: street-strip 700R4
well im gonna put a lt1 cam ,1.5 ratio roller rockers,3.42 gears posi,edelbrock performer maniffold with tbi adapter,high lift vavle spring with screw in studs and my tbi port and polish?how much power will i gain and what ets diffence will i see?
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
Do you have a base line, other than the stock numbers from gm? I'm not sure on hp numbers, but I would guess you'd be running mid 14's @ around 94-95mph.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Don't forget about chip burning. You can add all of those things and you will run SLOWER if you do not get a cutom PROM. I am friends witha kid on the board here who has everything done to his 305 and we are struggling with the tuning and the car was faster stock than it is now.
Engine: LO3;383tpi
The stage 2 is not a custom prom. You will need a custom prom to get your combo working to it's fullest potential.
Engine: LO3;383tpi
Best thing you can do is to burn one yourself, or find someone in your area with the equipement and experiance to help you. Custom chips such as Ed Wright's run over $300. An inexpensive alternate is http://ww.tbichips.com .
Also check out the DIY Prom board and take a look into the the Prominator. Very, very awesome stuff. I think it is nearing completion, and my be released before you finish your mods. I can't wait for it!!!
