Need 4th gen rear end
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
Re: Need 4th gen rear end
I've seen several V8 4th gens in the pick-your-part yards, but you gotta be willing to pull it yourself. If you are going to be choosy about gear ratios, your options diminish substantially.
TA
TA
Thanks for the tip.
Since the gears in my existing rear end suddenly became nothing but a pile of shrapnel, I'm more interested in getting the car going again than finding the ideal ratio.
Car: 91 RS Vert/98 Sierra9
Engine: 5.7/5.0
Transmission: 5spd/auto
Axle/Gears: 4th gen rear with 3.73
I have one off of a 94 z28. Its a parts car and i was told it has 3.73's on it. Complete from disk to disk. I have not removed it from teh car but can remove it soon.
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
Yeah, sure you can find a fourth-gen rear end at a "pick-your-part" junkyard, but most are basic non-limited slip, drum brake rear ends from v6's mostly.
So it makes it the same as a '90-'92 third-gen with the same 28 spline axles accompanied by a non-limited slip rear end and drum brakes. It's pretty hard to find something other than that at a junkyard unless you camp out early perhaps or know a good jy.
1992rs/ss
Jan 31, 2025 05:10 PM
hectre13
Dec 11, 2023 08:14 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
AkDrifted
Aug 17, 2015 07:45 PM
