hard top vert to t-top?
Car: 1991 camaro RS
Engine: 305-LT1 swap
Transmission: 700
I was just wondering if anyone has ever done a convention from hard top to t-tops. under the head liner there is a t-top like frame i think all third gen camaros came out of the factory with the ability to have t-tops but not all got the privilege of heaving t-tops people say "buy a camaro with t-tops" but the car is to sentimental. I always loved the feeling of havening t-tops that cool breeze going at you wile driving down the beach. i seen videos and photos of how its done (but not detailed enough) so i was wondering if anyone here has ever done this or know someone that has,? so they could guide me in the right direction. thanks
Car: 1986 iROC-Z Z28
Engine: 305 TPi
Re: hard top vert to t-top?
i wanna do the same to my car, and ive been searching online to see how much it cost to get it done and i read somewhere that it cost $1500 to convert but im not for sure tho, i seen the price on a forum.. u can always find a place that will do it for cheaper. thats if money isnt a issue for you.
if anyone else knows where to get this done cheaper i would like to know. thanks
There was recently a guy on the body boards doing something similar to what you are talking about. Basically what he did was find a car with a t-top roof. Cut the roof off at the pillars and replaceed his hardtop with the t-top. This was just the simplified version. He did a lot of bracing to the car before cutting the tops so things didn't shift around.
Engine: 305 TPi
There was recently a guy on the body boards doing something similar to what you are talking about. Basically what he did was find a car with a t-top roof. Cut the roof off at the pillars and replace his hardtop with the t-top. This was just the simplified version. The did alot of bracing to the car before cutting the tops so things didn't shift around.
do you know roughly what that will cost to get it one that way?
Car: 1982+1988 Z28 Camaros
Engine: 1982=350 carb 1988=383 Carb
Transmission: 1982=4 speed T-10 1988=6 speed T56
Axle/Gears: 1982=stock
Jason has it right, I read that same thread. I wanted to do this too until I realized I wasn't up to the task currently, and having some guy do it for me is financially out of the question. The guy might have also put in a cage to make sure it didn't have flex problems, in any case the cost would be the price of the roof (at pick-a-part or wherever you want to get one) and the cost to have it welded in.
Roof cost? At pick-a-part under 100 I'm sure.
Welding cost? Do it yourself and free, have a pro weld it in and you're looking at a nice sum for such a structural job, guessing around 600-800.
Car: '79 Camaro; '84 Z28
Engine: 350; none
Transmission: TH-350, 2500 stall; none
Axle/Gears: posi, 3.08; disc, 3.23
I finally found the thread about the conversion. https://www.thirdgen.org/forums/body...-top-roof.html
It was an interesting thread with some good information, but alot of work.
ambainb
Apr 25, 2016 09:21 PM
1Aauto
Sponsored Vendors
Aug 24, 2015 03:40 PM
