Southern California Area Southern California Members.
V6 or 305
Old Jul 31, 2009 | 11:45 AM
KG427KG427's Avatar
Car: 1991 camaro
Engine: 3.1L V6 dynomax exhaust
Transmission: 700r4 auto
Axle/Gears: 89 iroc-z 9bolt disc+posi 3.27
V6 or 305
Quick question.
i have 200k miles on my 1991 camaro rs. i should be able to get 300k before baring or something goes. But when it does go i want to prepare.
should i rebuild the v6 or try to find a 305 or something to put in. Im tight on money. i mean by all means if i can find a L98 thats a 91 year.
V6 isnt to bad getting 26 mpg
Old Jul 31, 2009 | 11:56 AM
Jason89RS's Avatar
Re: V6 or 305
Well what are your plans for the car? Are you going to use it for a daily driver commuter car or do plan to only cruise it on weekends. Do you want a fast 1/4 mile car or an autocross road race car or something inbetween.
Old Jul 31, 2009 | 12:41 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: V6 or 305
Plan on an engine swap costing you $3000-4000, no matter which engine you use.
Old Jul 31, 2009 | 04:08 PM
KG427KG427's Avatar
Car: 1991 camaro
Re: V6 or 305
Well i do drive 30 miles to work and 30 miles back everyday m-f.
L98 would be great but pros and cons...
i use my car everyday driver. its flawless perfect cond.
Old Jul 31, 2009 | 04:14 PM
Jason89RS's Avatar
Re: V6 or 305
Personally I'd go with a rebuild or new V6.
Old Jul 31, 2009 | 04:46 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: V6 or 305
To bad you can't legally use the V6 out of the 1989 Pontiac. I hear that one put out some good power.
Old Jul 31, 2009 | 05:55 PM
Jason89RS's Avatar
Re: V6 or 305
Or the 3.8 from the 87 Buick with related accessories.
Old Aug 1, 2009 | 08:06 PM
Tpx's Avatar
Tpx
Car: 1982+1988 Z28 Camaros
Engine: 1982=350 carb 1988=383 Carb
Transmission: 1982=4 speed T-10 1988=6 speed T56
Axle/Gears: 1982=stock
Re: V6 or 305
rebuild yours, a good rebuild can be had for about 2 grand.
Old Aug 2, 2009 | 12:49 AM
KG427KG427's Avatar
Car: 1991 camaro
Re: V6 or 305
Yeah i think im going to rebuild. Unless anyone has a L98
Old Aug 2, 2009 | 01:08 AM
quickkris2006's Avatar
Car: 1991 camaro vert
Engine: ls1 soon
Transmission: t56 soon
Axle/Gears: moser 12bolt 4.10 soon!
Re: V6 or 305
better yet find another 6 cyl motor from another camaro and rebuild that one so when urs goes all yea gatta do is yank and drop.. well u know what i mean
Old Aug 4, 2009 | 02:27 PM
WestCoastCamaro's Avatar
Car: 1984 Z28
Re: V6 or 305
305
Old Aug 4, 2009 | 05:51 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: V6 or 305
If anyone had an L98, you would need the whole donor car to have enough parts to do the swap.
You wouldn't believe the stuff you have to change.
Old Aug 4, 2009 | 08:28 PM
studdmstr's Avatar
Car: 91 Z28
Engine: LB9
Transmission: auto
Re: V6 or 305
Plus an L98 is a 350 which wasn't one of your choices. You'd have to do the same thing whether is was a 305 or 350 though.
pjsparts
Oct 29, 2025 06:39 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
rsrookie
Sep 5, 2015 07:08 PM
Formula_88AE
Sep 3, 2015 01:47 PM
