Southern California Area Southern California Members.
Headers Worth It?
Old Sep 21, 2009 | 02:24 PM
Projekt IROC's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 5.7L V8
Headers Worth It?
Im looking into getting some headers. I need them to be Cali/Smog legal since this is my daily driver. I was looking at the Hooker 2055 headers. http://www.jegs.com/i/Hooker/520/2055/10002/-1
Are these worth it/good? Or is there something better out there for Cali cars?
Old Sep 21, 2009 | 02:35 PM
racethesunlive's Avatar
Car: '92 Camaro
Re: Headers Worth It?
The smog portion of the hooker 2055's work and attach well to the stock AIR system. I didn't even have to bend or modify a single AIR hose when I installed my 2055 headers they just dropped right in and bolted up. Just be ready for a bit more heat coming off of the headers if you don't have them coated right away.
Old Sep 21, 2009 | 02:45 PM
Engine: 350 5.7L V8
Thanks for the quick reply. I would have them coated before installed, also would you happen to know if the headers will work with this http://www.magnaflow.com/02product/s...zone=all&id=96 exhaust setup?
Old Sep 21, 2009 | 04:57 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Check here:
https://www.thirdgen.org/forums/exha...s-exhaust.html
Old Sep 21, 2009 | 05:55 PM
kkingsrulee's Avatar
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
Originally Posted by Dyno Don
Maaan, look at you, advertising at every opportunity! Might as well get your ad put up on the site instead of the stupid one with bambi on the bottom.
And to the OP.
2055's are a b!tch to install (in my opinion) because of the lack of room to negotiate with. But everything does bolt on to the factory exhaust manifold locations. Except with the driver's side air hose I needed to get a small 2-3 inch length rubber hose about 1/12 inches in diameter from auto zone to connect the air tube from the 2055 to the air hose.
And you need to find something to connect a new air compatible catalytic converter to the air tube if you do decide to do that instead of reusing the stock catback.
This of course is only possible if you adapt the 3 inch y-pipe to the 2 1/4? stock diameter size.
Old Sep 21, 2009 | 06:14 PM
87Marro's Avatar
Car: 1987 Camaro Z28
Engine: 350 5.7L
Axle/Gears: Curently 3.43
They work well but will be tight in some spots when you need to change the spark plugs
Old Sep 21, 2009 | 07:10 PM
Russ-So Cal's Avatar
Originally Posted by kkingsrulee
Maaan, look at you, advertising at every opportunity! Might as well get your ad put up on the site instead of the stupid one with bambi on the bottom...
I think your remark is out of line. Unlike the hookers. Don's headers are relatively easy to install, spark plug changes are easy if the headers are not hot, and they are engineered to fit our cars specifically with the necessary wye pipes available to fit single or dual carts. He only posts when someone asks about headers, Should he be silent and let the guy buy something else that won't work as well or fit the engine bay as well just so he doesn't appear to be "advertising shamelessly." I almost posted a recommendation for Don's headers when I saw this post, but had to leave for an appointment. I have them on my car after trying and failing to find a way to keep SLP's from loosening up the bolts and blowing out the gaskets constantly. Don's headers were installed, the bolts tightened and they have never loosened up. I have about 1 1/2 inches of clearance between the left header and the steering shaft, unlike the SLP's that neede the "header bash" to clear.
Old Sep 21, 2009 | 08:57 PM
Car: 1990 Camaro RS
Engine: V8 305 TBI
Axle/Gears: 3.08
It was a joke sherlock.
Old Sep 21, 2009 | 09:56 PM
Engine: 350 5.7L V8
Easy guys. Lol gotta remember kkingsrulee, sarcasm doesnt work over the internet lol. I will be in contact with Don to see if i can work something out. If not ill go with the Hooker 2055s. Thanks for all your input. If anyone else has anymore info on the Hookers or Dons feel free to let me know. Thx again.
Old Sep 21, 2009 | 10:46 PM
89 TA's Avatar
Car: Trans Am/Kenworth
Engine: 383/435 Cat
Transmission: T5/10 speed
I'll make you a deal. I gotta get me a set of Don's headers so you can have my edelbrocks for $500.
Old Sep 23, 2009 | 04:23 PM
Engine: 350 5.7L V8
I hope you were kidding
Old Sep 25, 2009 | 04:53 PM
captain_camaro's Avatar
Car: 1989 camaro Rs or iroc clone??
Engine: 5.oh tpi
Transmission: borg warner t5 world class
Axle/Gears: 3.23-GU5
i got edelbrock 50 state legals off summit on mine.....sounds good...just that i keept burnin my plug wires as well as other electrical components
just make sure you re-route everything....i did, and no problems yet
Chad Speier
Sep 24, 2015 12:32 PM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
dennisbernal91z
Wheels and Tires
Sep 12, 2015 12:28 AM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
