The quality of Dyno Don's exhaust work.....
Car: 1988 Camaro(92 Z28 clone)
Engine: Forged 383, AFR 195 419/430@wheels
Transmission: Monster 700R4 Yank 3600 stall
Axle/Gears: 9in Detroit locker-3.90's,35 spline
is freaking spectacular!!!! I had to switch over from long tubes to a shorty configuration because of my transmission swap and can't believe the quality and fitment of these pieces, it's amazing. The headers are 1 3/4 primaries with 2 1/2 inch collectors and have some kind of nickel/chrome finish to them and they look great. They also utilize ball flanges for all the connections, so no need for gaskets and pesky exhaust gas leaks associated with them. Spark plug and spark plug boot clearance is awesome, and I am using AFR heads. The y pipe appears to be made out of stainless steel and the welds are perfect. The routing is precise, fitting right between the k member and the oil pan with no hitting or rubbing. The y pipe is 2- 2-1/2 in tubes merging into a 3 inch Y following the factoy routing. Even if all the stars and the planets in the heavens were perfectly aligned, they wouldn't line up better than this exhaust system. All I have to say is that if you are looking for a quality exhaust sytem, want a factory style fitment and routing, increased exhaust flow, no ground clearance loss, and ease of installation, then you need to get a hold of Dyno Don and he will hook you up! Well, what are you waiting for, open up your PM box and shoot him a mesasage!
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: The quality of Dyno Don's exhaust work.....
Yep, Don is building me up a special set of headers so that I can use my exhaust termination boxes. The spark plug clearance is about the best I have seen for my AFR 195 heads. The header bolts go in easily to. The best thing is the horsepower potential. With my new motor I expect to exceed 500 flywheel horsepower and without long tube headers.
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I had thought about ditching my LT's for a set.
Let us know how it works out. Sure would be nice to see what difference it makes on a dyno.
Car: 92 trans am clone
Engine: LO3
I just bought a set and I dont know why I didnt think about buying them before theyre gorgeous theyre art I havent even put them on yet I have to order a y pipe now. Great quality and construction A+ product I wouldnt buy anything else not even longtubes nor SLP shortys.
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
I got a set 5-6 months back, and was extremely happy with them! i had one small leak issue at the ball flange but its taken care of now, and has been great ever since! Very worth the money.
I've been trying to figure a way to get them up here to Canada. But I guess the fellow I was in contact with is not interested in selling and sending a set up to Canada.
Guess I'll have to shop for another brand and research here on the boards the next best set of headers for my engine swap over the winter......
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Car: 1987 Trans Am
Engine: LQ9/L92
Car: 87 GTA
Other than the higher cost of shipping, I never found it to be a problem shipping my STS tail light controllers, other than higher cost (vs 48 state shipping, which shipping cost varied on distance anyways) and an extra piece of paper to fill out.
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
90% of the population of Canada is within something like 300km's of the U.S. border, so I am not sure why shipping to Canada is so much more expensive than shipping within the 48 states.
Car: 1987 Trans Am
Engine: LQ9/L92
You are very correct on that one. The problem is that imaginary line in the sand that was drawn. That line results in 3-5 times the required paperwork, not to mention the fees and duties and customs and fun times associated.
Another reason why a lot of our Canadian customers close to the border have their packages shipped state-side; lower (free) shipping, better tracking numbers, and quicker turn around time. I can get parts to New York in 1-2 days; once you go over the border it mysteriously takes 2-3 weeks.....
Car: 87 GTA
I know you got headers in stock you pmed a few weeks back you did.
I won't deal with that fellow again and I'll check out a few shipping leads and see what I can do to ship them up.
Car: 85 trans am
Engine: 383 stroker
Transmission: 5 speed
Axle/Gears: 9 bolt rear 3:70
ill also attest to the greatness of dyno dons headers. they look and fit great. couldnt ask for anything better. i bought mine a few months ago but havent gotten a dyno done yet but i expect to see good things. i feel sorry for those who have our cars and dont have access to these gems. thanx again don!!!!!
Car: 1985 camaro z28
Engine: 355 sbc what else
Transmission: TH 350 manual vb/ 4200 stall
Axle/Gears: 4:30 on the street
anybody got a pic of these headers, i would like to see what everyone is talking about. Sounds like the setup is pretty sweet
Ask and you shall receive!! This is the only pic that I could find on the internet at the time but it is definitely the kit that i bought from Don....well minus the y pipe section.....anyways.....
I got my headers without the A.I.R injection tubes, but you get the idea...
Car: 1991 Z28 Camaro
Transmission: WC-T5
those are 1 3/4 primaries right??? also what diameter are the collectors and y-pipe?
ahhhhhh yes those a very nice looking. props to ya dyno don
Yep, the primaries are 1 3/4 in. The gasket flanges are a staggering 3/8 in thick and really reduces the possibility of warping and creating a header gasket leak. The collectors are 2 1/2 in utilizing ball flanges. The y pipe is also 2 1/2 in and merges into 3 in with a y pipe section(not pictured above).
Car: 1989 GTA
Engine: 369 TPI
I have been hesitant to show the special set of headers Don has built for me. They are a one off deal and you cannot buy them because they are made specifically for my car. They need the air pipes installed and ceramic coated but they are pretty much done otherwise. The collector pipe on the passenger side will have to be final fitted with the new motor install.
Car: 1989 GTA
Engine: 369 TPI
One more picture. You can see the quality of Don's work. By the way I don't think he is going to do anymore of these. The time and cost is to much.
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
For what engine are those headers for they look like they are worth alot
Car: 1989 GTA
Engine: 369 TPI
I'm in the process of building a sbc 6.0 liter motor. I will be using exhaust termination boxes so that is why the special configuration of the headers. I also have to use a tubular K-member for these to fit and a special oil pan. I have not totaled up the cost because I do not want to know.
Car: 87 GTA
I wonder if the headers could be made, with the AIR tubes n the bottom of here they are?
If the Inspector glances & says"No tubes, you fail." Look again!
Seems like it wouldn't create a spark plug or plug wire clearance problem. What about it Don? Possible?
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Not my car, but some good shots.
No AIR and single catalytic converter style.
Spark plug access picture
Car: 1991 Camaro Z28
Engine: L98 5.7 350 TPI
Transmission: Brand New (again) 700r4
Axle/Gears: GM 10 bolt 7.625 W/ TrueTrac 3.23
what do these usally run???
HOLY SH*T that looks good..............DAMN
Looks like I am getting a set with the Y pipe. From the looks of these pictures it will be worth the wait. Got in touch with one of the distrubuters and found out how to order it and sent the order off last night.
@ the dude that wants to know the price PM Dyno Don
FYI I am putting down 370/410 to the rear wheels w/355 in my car with these.
here is a pic of the AIR set:
Car: 87 Camaro
I wish my headers cleared the plugs like that. I have to take them off to take my plugs out -.- I'm also curious as to how much these run!
Car: 87 GTA
So...You are saying that your headers have been CARB/EO tested & certified, to be fully legal headers? I've never noiced the CARB/EO plate on yours, in the pics I've seen of them.
If not, your headers are no more emissions legal, than a http://www.summitracing.com/parts/HED-69520/ that someone added AIR tubes to, at home.
Car: 1986 Camaro Z28 IROC-Z
Engine: LB9 305 TPI
LT1Formula
20
Nov 14, 2015 12:02 AM
Linson
Aug 21, 2015 02:12 PM
