Southern California Area Southern California Members.
Dyno Day - Volume III
Old 09-23-2009, 11:04 AM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
I'll be ready whenever everyone else is ready
Bill
1.
2.
3.
4.
5.
6.
Old 09-23-2009, 11:44 AM
Guest
Guest
Posts: n/a
Re: Dyno Day - Volume III
Please could you remove the Dinosaur wheel and weigh it for me?
Old 09-24-2009, 02:11 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Julie needs a new fuel pump, Luis needs to get his injectors installed and his fuel figured out, and Vincent needs to give me back my plastic air intake. Then we'll be ready.
Old 09-24-2009, 07:22 PM
godreject's Avatar
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
fuel pump arrived today, injectors are on the way, plus i have a new diaphram i need to install for the afpr, i hope we are at least 4-6 weeks out to gives us all time to get our problems resolved. i have no fuel pressure...... im dreading changing out the fuel pump as i can't afford to have my car non-op right now its the only transportation i have,
im in for sure considering theres enough time for repairs, but setting a date wouldnt be a bad idea so we all have a schedule to work with
ps. i really really hate my car(right now)
Old 10-04-2009, 12:24 AM
Imadude_134's Avatar
Car: 1991 Camaro RS
Engine: L98 350 TPI
Axle/Gears: ZT LSD with 3.42 - LS1 brakes
I would want to sign up for this one... and hopefully i will be able to make it!!!
Old 10-13-2009, 09:33 AM
Burnout91's Avatar
Engine: Modded L98
Have you folks been able to make any progress on these issues?
Bill
Old 10-13-2009, 12:14 PM
thegooseman's Avatar
Car: 1992 RS
Bill
My new CAT should be in today then I just need my headers and new y-pipe installed. After all that I should be good to go
Old 10-13-2009, 12:27 PM
godreject's Avatar
this is what my car looks like right now, so unfortunately my car will be non-op the next few weeks, also depends on weather
Old 10-13-2009, 12:38 PM
TA
TA's Avatar
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
I am tunnelling through the rocky mountains (porting my intake) and had another emergency project come up as well. I also need to sort out my fans and I might be swapping cams/valve springs as well, so it's gonna be a few weeks.
TA
Old 10-14-2009, 01:41 AM
JulieGTA's Avatar
Car: 1991 GTA
Engine: 350 tPI
Axle/Gears: 342
I also don't have any specific date set for the fuel pump.
Old 10-14-2009, 03:04 AM
Red87SC's Avatar
Car: 87 Trans am
Transmission: built 700R4
Axle/Gears: BW 9 bolt posi w/ disc
i need to put a new rear axle in my TA before i run it hard. Both axle shafts are tweaked a little bit and im not really sure that i want to run it hard on the dyno until thats all fixed up..
I would like to get some more mods but this whole buying my first house is getting in the way lol
Old 11-11-2009, 09:49 AM
Burnout91's Avatar
Engine: Modded L98
Will anyone be ready before year-end '09?
Bill
Old 11-11-2009, 10:17 AM
Car: 1991 Camaro RS
Engine: L98 350 TPI
I'm ready to go... I just need to know when so I can know if I can afford it or not
Old 11-11-2009, 12:56 PM
TA
TA's Avatar
Axle/Gears: 9bolt
Recovering from a surgery, so the porting is only half done. Cam change is still a possibility, but will require new springs. Nothing else on this car has gone smoothly, so I don't know I still bother being optimistic...
TA
Old 11-12-2009, 10:43 PM
Car: 1992 RS
My headers and y-pipe are in, so all I need is for you guys to tell me a date.
83RDRACR
03-26-2016 08:13 PM
92-Formula
12-12-2015 10:34 PM
PeteK825
09-22-2015 10:47 AM
Bubbajones_ya
09-14-2015 08:38 PM
Ranbo108
09-09-2015 12:20 PM
Quick Reply: Dyno Day - Volume III
