Shining it up
Car: '02 Z06
Shining it up
Anyone know anyone who can spray my '91 Z for a decent price (pretty cheap)? All the prep work is done by me so all I would need is to have it sprayed.
Car: 1986 Grand Prix TPI
Transmission: 200 4R
Re: Shining it up
Paint shops will not guarantee the paint job unless they prep it and since you have primed it you are probably SOL.
IIRC they wont even guarantee it against runs.
Guest
Posts: n/a
Re: Shining it up
maybe you should check out the job they did on my "vetruck"
2 stage and color sanded for $2100. It turned out quite beautiful.
2000 vette color Pewter Pearl Metallic.
They also did a grat job on a '77 ElCamino I had. Single stage for around $700 if I recall correctly including spraying the bed.
Car: 1991 Camaro RS
Engine: L98 350 TPI
Axle/Gears: ZT LSD with 3.42 - LS1 brakes
Car: '02 Z06
Re: Shining it up
But anyhow I wasn't exactly referring to a shop, I was referring to if anyone knew someone personally that could do it for a good price and I could check out there work. I may have something lined up though..
Street Lethal
Apr 30, 2019 12:14 PM
