drum vs disc
Car: 1991 camaro
Engine: 3.1L V6 dynomax exhaust
Transmission: 700r4 auto
Axle/Gears: 89 iroc-z 9bolt disc+posi 3.27
drum vs disc
I have a 1991 rs great car 230k miles on it. I plan on rebuilding the engine when my v6 dies and im planning to have my car for another 10 years+. Make a long story short, I came across a axle off a 89 iroc 5.7 i took it off his hands for 80$. Would it be worth it do put this axle comes with disc breaks on my 91 camaro rs. And how much would the work cost. I was hoping under 600$ for labor parts everything. Pros and Cons ? I have always wanted disc and will look much better when i put c6 rims on my car
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
Re: drum vs disc
you mean a rear end not axle right, you might want to check the gearing that will let you know whether it's worth it or not. might be 2.77 or 3.27
Car: 1991 camaro RS
Engine: 305-LT1 swap
Transmission: 700
Re: drum vs disc
i used to think there was really no BIG difference in drum vs disc. but after swaping the rear on my 91 from drum to disk, i felt a difference especially when it came to wet weather.
Car: 1991 camaro
Re: drum vs disc
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
KO1
16
Oct 15, 2015 05:00 PM
