How bad is this?
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
How bad is this?
Came out of my 15 yr old compressor, 25 gl.Im afraid the integrity of the welds are compromised?Anyone have some experience/knowledge dealing with rusted compressor tanks.Im afraid to pressurise the tank for fear a pipe bomb blast will result.
Some of the bigger chunks
Car: 89 Formula 350
Engine: 355 long block TPI
Transmission: auto
Axle/Gears: Richmond 4:10 Eaton Posi
Re: How bad is this?
At the pressure your air tank is gonna run, most likely you'll just get a pinhole leak somewhere and it will whistle.. unlikely it's going to do a catastrophic fail, though they do put the big industrial ones in a cage for a reason. you might be able to find someone who works at an oil company who has specialized ultrasound equipment for testing oil tanks, who can check it for you?
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Yeah, tank is regulated to 140 psi.I feel a little safer using it then.
Would'nt mind having it tested though, thanks guys.
dimented24x7
Sep 17, 2015 06:58 AM
