Southern California Area Southern California Members.
Rim fitment question
Old May 18, 2011 | 03:37 PM
bungo78's Avatar
Car: 88' TA Digital Dash
Axle/Gears: 3:23 Posi Disk 10 Bolt
Hey SoCal!
Need some help figuring if how and if these rims would fit.
Here's The link I started on the other board with the info
https://www.thirdgen.org/forums/whee...n-fitment.html
A guy states that I should run 10's on all 4 corners. I know a spacer would be needed for the front. Would I need one for the rear if it's a 4th gen axle?
Would it rub up front with the spacer included? I don't want any rubbing or hitting of anything. I'm aware of guys here on the SoCal board running 9.5's up front with no problems i'm assuming.
With wheels, I have no freaking clue! lol!
Thought's?
Thanks!
Adrian
Old May 18, 2011 | 03:46 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
Re: Rim fitment question
I'm using 35mm offset 9.5 wide wheels with a 4th gen diff and they are pretty flushed with the rear quarter panel im assuming a 25mm offset would stick out approximately 1omm more than my current set up. My old 56mm offset 9.5 wide c5 z wheels tucked in with the 295 35 tires
Old May 18, 2011 | 04:21 PM
bungo78's Avatar
Are your fronts 35mm also? How do they turn? Do they rub @ all? What size spacer do you use?
Old May 18, 2011 | 04:58 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
35mm with 1.25 spacers 265 35 18 tire no rubbing issues besides the umi tubular a arms due to the absence of steering stops
Old May 19, 2011 | 05:14 PM
bungo78's Avatar
So with the stops it would prevent your rubbing on the A arm? Did you upgrade your front brakes? And is this the reason for the spacer up front?
Old May 19, 2011 | 05:30 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
Yea the umi design isn't the greatest they suppose to recreate them. I am running ctsv v1 brembo front brake set up
Old May 19, 2011 | 05:43 PM
bungo78's Avatar
I've heard quite a few kats purchasing these brakes. Do you like the set-up? Do you have a pic of them sitting inside the rim?
And I'm aware of the UMI A arms... lol!
Old May 19, 2011 | 05:55 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
I love these brakes I'm looking into a adjustable proportion valve since its too much brake up front
https://www.thirdgen.org/forums/brak...y-14-ctsv.html
Old May 19, 2011 | 05:59 PM
bungo78's Avatar
Old May 19, 2011 | 06:00 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
Lol
Old May 19, 2011 | 06:07 PM
bungo78's Avatar
Lol
Yo!!!!!! They look nice! So the spacer up front was to accommodate these brakes?
Old May 19, 2011 | 06:15 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
Yea Im running a 1.25 spacer they are perfect on these offsets
Matching rear brakes would be perfect ..Edmiller finished up rear brackets for rear brembos
Old May 19, 2011 | 06:24 PM
bungo78's Avatar
I needed to pick up my jaw when you said Ed finished the brackets. Figured it was a typo, then I re-read it lol!
Old May 19, 2011 | 06:31 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
Lol I might be in the market for that set up in the future.
Any luck finding wheels?
Old May 19, 2011 | 06:40 PM
bungo78's Avatar
I Agree! Found these 18x9.5
http://discounttires.com/detail_whee...category=Black
Old May 20, 2011 | 11:00 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
Originally Posted by bungo78
ive always like those. seen them on a gn and they look really good
Frozer!!!
Jan 19, 2024 04:55 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
kah992
Aug 19, 2015 02:55 PM
redmaroz
Aug 16, 2015 11:40 PM
Exxon Limited
Aug 9, 2015 08:13 PM
