Does my GTA run cleaner than my Toyota? Hmmm.
Car: 1991 GTA
Engine: 350 tPI
Axle/Gears: 342
I had to smog my cars this month so I took them both in today.
I started with the toyota, ('85 corolla) I figured if they passed that POS...
I didn't do anything special to either just warmed them up first.
__________________________%CO2___%02____________HC (PPM)_____
________ TEST____RPM______MEAS___MEAS______MAX___AVE___MEAS
Toyota:__15 mph__1825______14.41___0.63_______157____52_____46
Toyota:__25 mph__1847______14.37___0.61_______132____40_____39
GTA:____15 mph___1630______11.83___3.89_______108____31_____36
GTA:____25 mph___1590______12.89___2.33_______83_____20_____50
__________________CO%__________________________NO (PPM)_____
_________MAX_____AVE_____MEAS_________MAX_____AVE_____MEAS
Toyota:__0.93_____0.19_____0.00__________859______517_____0529
Toyota:__0.73_____0.14_____0.00__________740______430_____0505
GTA:_____0.71_____0.10_____0.09__________767______237_____0218
GTA:_____0.58_____0.09_____0.09__________706______199_____0194
I think they did just average, but it's fun to compare the numbers
I wonder if the higher O2 in the GTA is because it flows more air through it?
Also, am I allowed more leeway with the Toyota because it is a single cat and carbed?
Since they only put the sniffer in one exhaust, does my GTA actually put out as much smog as two Toyotas?
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
Re: Does my GTA run cleaner than my Toyota? Hmmm.
Hi Julie!
To answer your question, you have to look at how they evaluate emissions. They use both % (percent) and PPM (Parts Per Million), so looking at your figures can lead to some confusion.
Since they are evaluating your emissions on a percentage basis, the GTA can be emitting a lower percentage of emissions, but a much higher volume of emissions and thus emitting a far larger amount of smog into the environment.
The analogy that comes to mind is that if you dump 10 gallons of 20% dirty water into the environment, vs dumping 1 gallon of 25% dirty water, even though the latter is in fact "dirtier" water, the former is emitting far more "bad" particles into the environment.
So, is 'Yota cleaner than the GTA? Percentage-wise, the GTA is cleaner. But for total emissions volume, the 'Yota is probably cleaner.
TA
TA
Car: 1991 GTA
Engine: 350 tPI
Axle/Gears: 342
Thanks for the replies!
86IROC112
Sep 7, 2015 01:37 PM
86IROC112
Aug 17, 2015 02:00 PM
