rear main seal tips?(89 camaro)
Car: 1989 camaro Rs or iroc clone??
Engine: 5.oh tpi
Transmission: borg warner t5 world class
Axle/Gears: 3.23-GU5
i can take out the engine and fix it...but can i prevent that?
of course its gonna be a pain either way but, is there any smoother way of swapping a rear main?
BTW 5.0tpi/t5
thanks fellas
BTW 5.0tpi/t5
thanks fellas
Car: 1986 Firebird
Engine: 5.0L V8
Re: rear main seal tips?(89 camaro)
I'd like to know too. I dont want to have to pull the engine and tranny to do the mains and oil pan
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
You must remove the trans, remove the motor mount bolts, jack up the engine, put two boards under the mounts, remove the flywheel, remove all the pan bolts, drop the oil pump into the pan and then remove the pan.
From there you can get at the rear main.
If just the seal, remove the trans and flywheel. Then pry it out and replace.
Car: 1986 Firebird
Engine: 5.0L V8
1992 Trans Am
May 10, 2023 07:19 PM
