Any body pros here?
Car: 1991 RS/B4C clone
Engine: 355 TPI
Transmission: Probuilt Street/Strip 700r4
Axle/Gears: 7.625 axle with 3.23 gears/TrueTrac
Any body pros here?
I need some serious help with my passenger side door. I've replaced all the weather stripping on the door and I still can't get rid of the wind noise. Is there anybody here who has experience with this? The new stripping went on the driver side just fine, and hasn't been a problem.
Moderator/TGO Supporter
Car: 87 IROC 92 Z-28 91 Ragtop
Engine: 5.7
Transmission: 700-r4
Re: Any body pros here?
Engine: 355 TPI
I've adjusted it so it's not as bad as it was initially. However, every new adjustment comes with another set back. If I adjust it one way, I won't get a good seal along the roof line, but the corner will seal up nicely. If I get that right, the window is adjusted so far inboard that it won't roll up again if I roll it down. I've basically run out of patience and am hoping that a better mind that mine could fix it.
Car: 1990 z28
Engine: 5.0
Transmission: t-5 wc
Axle/Gears: 4th gen 3.42 posi
adjust the dooronly , ignore the window for now. use a piece of paper th check for gaps ( close the door on the paper and pull) if it sticks the seal is good if loose -bad . or you can use a hair drier on low heat , once the door is good start to roll the window up ( you will have to remove the door panel ,but its probably already off , so then adjust the window with the door closed you may want to have somebody helpby pushing on the glass against the seal while you tighten the adjustments . treat the new seals with clear silicoln spray to prolong their life NOT ARMORALL.
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
You replaced the weather stripping on the door, but your adjusting the window.Where is the leak coming from?
Engine: 355 TPI
I've replaced all the weather stripping. When all the new stripping went on, the window wouldn't seal properly against the roof rail and there was a nice sized gap between the bottom forward portion of the triangle and the roof rail stripping. At this point I just want to pay someone to do it right.
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Be cheaper to buy the haynes manual.It shows you how to adjust the window properly.I know how to do it, but im in OC.
Engine: 355 TPI
I have the GM book for the car and even it's rather vague as to how it's done. If you can do this well, I'll pay you to fix it.
Engine: 355 TPI
Beers, then. I could do that. When are you typically free?
Car: 1991 camaro
Engine: 3.1L V6 dynomax exhaust
Transmission: 700r4 auto
Axle/Gears: 89 iroc-z 9bolt disc+posi 3.27
I would love if you did mine as well but I Insist I have to pay you for your work. I got all new weather stripping and and got new triangles that rubber piece it's very frustration hearing the wind noise
Sorry for jumping on this thread
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
