Removing an Idler Arm.
I'm trying to swap the Idler arm on the Camaro out, but I'm not having much luck getting the old one off. I'ved tried a 2 jaw puller but I can't get it to bite. Would a pickle fork, or a tie rod remover work?
Thanks!
- Nick
Thanks!
- Nick
Axle/Gears: 3.45, 3.27, 3.27
Ditto for me. I rented one from Pep Boys. But for the amount of times I rented it I've been tempted to just buy one. But the time I wanted to buy it they were out of stock on the one I wanted. The set I rented included a fork you could mount in an air chisle. I gave it a whack though.
Be careful with the forks and you can f--k up the boots and then they are junk.
if you loosen the bolt connecting it to the center link so a few threads show, use a 5 lb sledge or brass and give it a good square hit. that will work and since the nut is still on you don't booger up the threads (mushroom). you can only hit it about 5 or 6 times then it will start to mess the threads up.
Barry
Barry
Thanks for the suggestions guys. A lot of banging with a pickle fork and it came right out. I managed to get the new one back on with the help of a C-clamp to hold it in place and stop the stud from spinning.
Unfortunately, I managed to drop an 18mm box wrench on myself and chip a tooth
- Nick
- Nick
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
