Installed Hurst Billet/Plus shifter last night
Car: Moving...
Engine: Running...
Transmission: Shifting...
Or should I say this morning (another 2am in the car port modification)
Anyways was very straight forward and easy to install once I "cut" through a few things. But now what I am going to blame my slopping shifting on!
LOL
LOL
Axle/Gears: 3.45, 3.27, 3.27
What cutting? I guess you got lazy and didn't take the console lid off. I hope you installeld the plastic piece onto the end of the shift lever before you put it onto the tranny. Otherwise you will still have something to blame. Lon
Car: Moving...
Engine: Running...
plastic piece?
I removed the shift plate, console lid, and the upper console off, well as much as possible without having to disconnect everything. The cutting I was referring to was that I cut through the stock shifter boot rather than unbolting the entire thing just to get at the stock shifter. I did then bolt in the hurst making sure to use their boot when I installed the shifter. What plastic piece are you referring to? not the boot I imagine?
Car: Cars
Engine: SB
Transmission: manual
Axle/Gears: 9bolt
I think he's taking about the plastic *** like thing at the bottm of the shift inside the tranny.
Did you cut the stock rubber boot that attaches to the floor board?
Car: Moving...
Engine: Running...
Yup, just enough to get the stock one out and the Hurst installed, I didn't completely thrash it I just figured it made more send to get through it to the shifter rather than taking forever to unbolt it from the floor board. I did make sure to check the bushing joint in the tranny and use the boot that came with the new shifter, Hurst even had a little paper insert stating out imperative it is to use their boot to keep the shifter "clean."
Car: Cars
Engine: SB
Axle/Gears: 9bolt
Cool. now you got a new potato masher (mashin gears), oar (so you can row through the gears), or grinder.
Did you tighten the stop pins?
NBrehm
Aug 25, 2015 11:49 PM
