Southern California Area Southern California Members.
limited slip unit
Old Mar 6, 2002 | 12:54 AM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
limited slip unit
Hey guys Im looking for a good used limited slip unit for my 1992 rs camaro. and some 3.42 gears to finish the reared off because i just got a slaming deal on an aluminum drive shaft so I want to do everything at once so keep me posted on some cool deals
92 teal RS 16.01@88.7
Old Mar 6, 2002 | 01:47 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Go to www.slponline.com and get their takeoff torsen posi for $99. Then go to the 4th gen boards, either www.camaroz28.com or www.ls1.com and buy someone's used 3.23 or 3.42 gears for $50. Dont forget about your speedo gears in your trans, too. They're about $20. Then take it to a good shop to have it all installed, as gear changes are complicated and require special tools and knowledge to do correctly. This costs about $200-300. Good luck!
Old Mar 6, 2002 | 09:11 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
'Scuse my ignorance, but doesn't he also need a series 3 carrier to put any gear ratio beyond 3.08 in his current housing?
Old Mar 6, 2002 | 11:03 AM
BGNCHRS's Avatar
The Zexel-Torsen take outs from SLP will handle 3.23, 3.42, 3.73 and I think 4.10. I have it with 3.23's
Barry F
Old Mar 6, 2002 | 03:14 PM
8T8IROC's Avatar
Car: Moving...
Engine: Running...
Transmission: Shifting...
Nice to see ya post
Hey there Rusty, I know its got nothing to do with the thread you started here, other than the fact that I would like the same setup for the RS, but just thought I would welcome you to the board
Old Mar 6, 2002 | 07:14 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
The torsen take-off posi SLP sells *IS* a 3-series carrier.
Kevin
Old Mar 6, 2002 | 07:21 PM
lonsal's Avatar
Good to know if you've got a 10-bolt, (which I don't anymore). Lon
Old Mar 6, 2002 | 07:36 PM
8T8IROC's Avatar
Car: Moving...
Engine: Running...
I'll trade ya...
My 10bolt from the RS
Old Mar 7, 2002 | 09:26 AM
lonsal's Avatar
Sorry. I didn't mean to imply I wanted a 10 bolt. Just remove one bolt and it will be a 9-bolt! LOL
Old Mar 7, 2002 | 02:42 PM
Tas's Avatar
Tas
like I said before Kevin deleted my post: Just get a v6 rear with 3.42s and a $85 SLP posi and save the money you'd be giving for the price of gears plus the price for someone to install them. I saw $400 around Northridge for GM gears including install, for a price comparison.
Old Mar 7, 2002 | 02:53 PM
8T8IROC's Avatar
Car: Moving...
Engine: Running...
OR..
You could add two more and make it a 12 bolt, wow now that's a way to save some money :lala: LOL!
Old Mar 7, 2002 | 03:33 PM
Dyno Don's Avatar
V-6 rear
Got any idea what a '90-92 V-6 rear w/3:42's would cost (w/28 splined axles?
Do the math!
Old Mar 7, 2002 | 03:36 PM
Tas's Avatar
Tas
can't be too much. 90% of the thirdgens in the pic U parts around here are v6s. Pablo got his for $50
I do lots of math. I have some differential equation problems due monday, thank you.
Old Mar 7, 2002 | 04:30 PM
Guest
Guest
Posts: n/a
If you could find a used rear for $50 (good luck, boneyards around here charge more like 80+ plus core) you'd still have to set the pattern and backlash, since carriers and bearings all not all created equal. Thats if you want it to be right anyway.
Old Mar 7, 2002 | 05:36 PM
Kevin91Z's Avatar
I didnt do crap to you. And like Chris said, you still have to double check the pinion setting, backlash, and preload if you want it to be 100% correct.
Old Mar 7, 2002 | 05:45 PM
Tas's Avatar
Tas
Old Mar 7, 2002 | 07:32 PM
Guest
Guest
Posts: n/a
Well, I always knew you didnt know a whole lot and this just proves it. Tell me Tas, exactly how many gear swaps have you done? How many differentials have you setup in your life? How many times have you had to change out a bad carrier with a new one? Sometimes they work out ok just swapping one in for the other. I've never had such luck. I had one that was so much different, the gear wouldnt even turn.
Keep on passing bad advice, maybe someone will get pissed off enough at you to come after you.
Old Mar 7, 2002 | 08:15 PM
Tas's Avatar
Tas
I wasn't BSing about that. I did it because someone deleted my post. And it wasn't him, who was it?
Old Mar 8, 2002 | 01:28 PM
Guest
Guest
Posts: n/a
Any admin could have deleted the post too, so it wasnt necessarily Kevin that did it.
Old Mar 8, 2002 | 01:39 PM
BGNCHRS's Avatar
now back to our regularly scheduled programming
:sillylol:
Old Mar 17, 2002 | 03:00 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
hey guys thanks for the help I orderd my limited slip from slp on friday with was 96 bucks shiped and i got a set of 3.42 gears for 40 bucks out of a 2000 ws6 from a guy on the IE f-body web site. the gears dont even looked used. they only have 20000 miles on them
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
jrdturbo
Mar 31, 2016 02:58 PM
racereese
Oct 3, 2015 03:46 PM
gord327
Oct 3, 2015 01:25 PM
ironbmt
Sep 27, 2015 06:00 AM
