Sponsored Vendors Connect with our Sponsored Vendors that sell the parts you need for your Third Gen Camaro or Firebird. Show your support for our vendors by offering feedback and telling friends about their services.
Pontiac Firebird Heater Core 1982-92
Old Mar 27, 2009 | 09:34 AM
1Aauto's Avatar
Former Sponsor
Part Number: 1AHCC00028
This new replacement heater core is just what you need to get your vehicle in good running form again!
Specifications:
  • Copper & Brass construction
  • Replaces one of many dealer part numbers including: 3048945, 52479879
  • Core measurements: 7 x 7 x 2 inches
  • Inlet Tube Outside Diameter: 5/8"
  • Outlet Tube Outside Diameter: 3/4"
  • Direct replacement
  • Built to strict quality control standards
If your heater is not producing heat, or you can smell coolant inside your vehicle, or you see coolant leaking inside your vehicle it is time to replace your heater core.
If the coolant in your vehicle has not been properly maintained it can corrode and or block the coolant tubes inside your heater core. Once the heater core is blocked or leaking the only effective repair is to replace the heater core
CLICK LINK BELOW TO PURCHASE THROUGH OUR WEBSITE.
NOTE: DOES NOT FIT THE FORMULA
THIS ONE DOES FIT THE 87-92 FORMULA
Pontiac Firebird Formula Heater Core 1987-92
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
TheExaminer
Aug 26, 2015 04:59 PM
lakeffect2
Aug 23, 2015 08:44 AM
1985chevydude
Aug 22, 2015 05:36 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
