1986 - 1991 Chevrolet Camaro Rear Hatch Pull Down Motor
This GM replacement trunk pull down motor motor is among the highest quality replacements on the market. It's just what you need to get your vehicle in good working order again!
1A Auto Parts Offers FREE SHIPPING On All Orders.
Car: 1989 Camaro RS
Engine: V8 5.0
Transmission: Automatic
Re: 1986 - 1991 Chevrolet Camaro Rear Hatch Pull Down Motor
hello mine doesnt even close, you can shut it down but wont lock, it does have a motor but i can only hear the click of the button when i press it. Where do i have to start first? what are the parts i need to look for? Need help please. thanks
Car: 1989 Camaro RS
Engine: V8 5.0
Does anyone know where i can get a picture or diagram of how the rear pull down motor trunck goes?
How did you test the power going to it?
The motor is new and I can put power straight to it out of the car and it will run. I have power to the relay and to the plug that goes to the motor
Strange, is it a new relay that was replaced? I'm wondering if there's not enough power coming out of the relay to the motor.
Car: 1989 Camaro RS
Engine: V8 5.0
HELLO TONY, I HAVE A QUESTION FOR YOU, I ALMOST HAVE ALL THE PARTS I NEED FOR THE HATCH PULL DOWN MOTOR, I WAS LOOKING AT THE VIDEO YOU GUYS HAVE ON YOUTUBE ABOUT REPLACING THE MOTOR. THE FIRST THING THEY DID WHEN REMOVING THE HOUSING WITH THE MOTOR, THE UNBOLTED WITH A 11MM SOCKET, I JUST NEED TO KNOW WHAT KIND OF BOLTS WHERE THEY? I THINK I HAVE ONE, BUT NOT SURE WHERE I CAN BUY THEM. WILL YOU PLEASE HELP ME OUT.
THANK YOU
THANK YOU
Car: 1989 Camaro RS
Engine: V8 5.0
BY THE WAY CAN YOU SEND ME A PIC OR POST ONE UP OF THE SCREWS, PLEASE.
THANK YOU,
THANK YOU,
THANK YOU
THANK YOU
If you post up in the interior part of the forum, one of the members might know what size they are.
Car: 1989 Camaro RS
Engine: V8 5.0
Thank you 1A Tony, i found the bolts i need the size are # 14 x3/4 got them at napa part # 665-3266. I tried it on the old motor housing only because i didn't want to mess up my new motor with housing, and they worked. Tomorrow i'm going to put the pull down motor on my camaro RS wish me luck, hope it works!!
Car: 1989 Camaro RS
Engine: V8 5.0
OK ME AGAIN, I PUT THE REAR PULL DOWN TRUNK MOTOR IN, I PLUGGED IN THE MOTOR JUST LIKE THE VIDEO, AND WHEN I DID THAT, I DID NOT HEAR THE MOTOR WIND. NO NOISE, NOTHING, THE INSIDE LIGHT TURNS ON, SO IM THINKING THERE IS POWER BACK THERE, IF I PRESS THE SWITCH INSIDE THE CAMARO BY THE ARM REST IT CLICKS. WHEN I PUT THE KEY IN THE LOCK CYLINDER, IT WONT EVEN DO ANYTHING EITHER. WHAT CAN IT BE NOW? I NEED HELP PLEASE.
Car: 1989 Camaro RS
Engine: V8 5.0
Got it working!!! The relay that goes on the motor had a up and down switch, just had to adjust the gear nut, so many times so the rear hatch could open up.
Car: 1991 Firebird
Engine: 5.0l V8 TBI
Transmission: 700 R4
Hey, I have an issue with my pull down motor. I just purchased my 91' firebird a couple months ago , and this is one of the minor issues she has.
The motor does not lower. The latch seems to work fine, but only works with the key. When I push the trunk release button, I hear a rapid clicking noise, but nothing else happens.
Does this mean my motor is bad?
I'll remove the motor this weekend when I have time. I've watched your video on youtube and it looks simple enough.
Thanks,
Frito
Thanks,
Frito
Car: 1988 Iroc-Z Red T-tops
Engine: 305 TPI LB9 55k miles
Transmission: Auto 700r4
Axle/Gears: 2.73 posi
I just bought the motor housing but I realize I am missing the reverse switch and the keylock assembling I am missing the key so I need a new one. the latch release opens the latch but not sure if motor will work without the reverse switch but it has 12v so should be fine
do you sell new key assemblies that fit the trunk. I bought a cheap advanced auto one and the tumbler shaft that should turn the hatch release was so flimsy and so thin it would stay in position. Looking for a 3 key lock set so both doors and trunk use same key? or can i re key originals?
also do you sell the reverse switch?
Tony
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
Linson
Aug 21, 2015 02:12 PM
