i just did my motor mounts
Old Apr 14, 2002 | 05:40 PM
jerflash's Avatar
Car: 90 Formula, 02 ws6
Engine: 305 tpi, ls1
Transmission: 700r4, t-56
Axle/Gears: stock posi 2.73, 12 bolt with 4.11s
what a PITA this was one of the hardest things i ahve ever dones on my car
i put energy suspention poly mounts in
im lucky that i had ny dad to help me
if you dont need to do them consider your self lucky
took me about 8 hours to do and the hardest part is taking out and putting back the bolts that hold the mount to the frame
you have to go through the front control arm in little spots that you can and be thankful that you dont drop any nuts inside the k member luckly i did not
and on one of the passenger side bvolts you have to go through the coil spring if you dont want to take the control arm down
what hell
but it is done and my headers dont rattle any more on the frame but now since the motor is raised from the new poly motor mounts my flowtech y pipe sits flat aganst the floorboard and vibrats but atleast its not and bad as it Knocking
and my motor does not what to lift out of the car anymore
it was worth it but
what hell
Old Apr 14, 2002 | 10:53 PM
5 litre eater's Avatar
Car: '84 Trans Am
Engine: 350ci Sportsman heads, B&M blower
Transmission: Turbo 350
Other than solving your header problem(I've got that too) did the new mounts inprove anything else?
Old Apr 15, 2002 | 11:48 AM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
Transmission: 5 speed
I recently did this because I was pulling my a-arms and springs for upgrades. I figured since I'm doing the major stuff already, I'd do the mounts, as well. Good thing, too. They were shot.
Old Apr 15, 2002 | 12:33 PM
jerflash's Avatar
well it also improved the way the engine rocked when you pwer braked it of reved it had or took off hard
the motor does not lift anymore and it does not rock back and forth at all
i recoment if you are going to change them get the polys there the only monts out there worth replacing the old ones will
if you put rubber ones back you will have the same problem
Old Apr 15, 2002 | 02:20 PM
Car: '84 Trans Am
Did you also do the trans mount and if so did improve shifts? I'm entertaining the idea of doing today, any tips? It looks like a teach the neighbors new swear words job.
Old Apr 15, 2002 | 03:44 PM
jerflash's Avatar
did did the tany mount and the torqarm mount when i changed out the tranny
they did help out a little and now that i did the motor mounts my whole drive train is poly now except for the control arm and panhard rod
it tightens up everything alot
you may get a little more vibs but not bad and it is worth it
Old Apr 17, 2002 | 02:50 PM
sy2449's Avatar
i cant figure out the energysuspension part numbers. does anyone have the part number handy for the energysuspension motor mounts? its a 91 rs
e
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
