Hit a bump and i'm out of control????
Car: 1983 Z28 Clone
Transmission: TH350
hey guys... finally got the camaro on the road...pretty awsome..but......when i hit a pot hole..(lots from the salt)my car ..well it feels like the back end is swinging left and right...and i have to yank on the wheel..... like in nascar when the car gets "loose"....i have to cut the wheel in the drirection i'm going........
rear shocks are shot ...but would that cause horizontal movement???
its exhuasting to drive
thanx..
rob
thanx..
rob
Car: 1991 Pontiac ta 5.0l 2005 pontiac gxp 5.3l ls4 dod 2003 GMC Envoy 4.2l
Replace the shocks and maybe springs depending how bad they are. That a start and not to hard while your doing this check all rear end parts and bushings for wear.
Car: 1983 Z28 Clone
Transmission: TH350
actually i just read a post where people said it could be "bump steer" ....i do have some pretty fat tires on......they stick out of the well pretty much.......or i think i heard it called "hunting'.....sorry....to post...i just found that info..but....i am going to replace the rear bushings...
they are all cracked...... do i have to order these from GM.....or will locals like pepboys have them..
thanks
rob
thanks
rob
Car: '08 Mustang GT
Engine: 4.6L
Transmission: º º 0 . . . |-|-|
Axle/Gears: 8.8", 3.55
Re: Hit a bump and i'm out of control????
Originally posted by 350turbo411
. . . rear shocks are shot ...but would that cause horizontal movement??? . . .
A wheel that's up off the ground has zero grip, so for a few milliseconds at a time for each bump you have much less lateral grip out back, and it will swing or "skitter" wide. Since the car is suspended on springs the weight carried by the right wheel (for example) does not immediately transfer to the left wheel. Even in a straight line with an open diff you have unequal traction during millisecond-magnitude periods of time, which will rotate the car slightly.
Norm
Car: 1983 Z28 Clone
Transmission: TH350
huh....i didnt know that ...thanks norm...i think i'm off to get new shocks.....i just wanted to get some input......
very informative......AND IT MAKES SENSE!!!
rob
rob
wigmobile
Feb 26, 2025 02:56 PM
Doobie52
Sep 11, 2015 06:19 PM
