92 RS Suspension
Old Apr 15, 2002 | 07:16 PM
man_of_steel27's Avatar
Car: 92 RS - For sale
Transmission: 700 R4
Axle/Gears: yup, it has a peg leg
92 RS Suspension
I just baught a 1992 RS Camaro and I will be driving it as a everyday car like many others, well one of the first things I want to do is upgrade the suspension good or bad idea? If so, what should a do I am fairly new to racing scene. Keep in mind this will be a street car.
Old Apr 15, 2002 | 07:22 PM
camaro6spd's Avatar
first things first
get a wonderbar, Strut tower brace and sub frame connecctors
i frovve a car with out ne of these and it sucked, felt so sloppy.
Old Apr 16, 2002 | 06:04 AM
racereno's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock
Hey m_o_s. I think you'll see plenty of replies about sfc, stb, etc, etc but don't forget the true basics. Check the condition of all your present suspension components. Some stuck bushings, endlinks, and what have you aren't found by just looking. You may have to do a little disassembly but you'll know where you stand and not be dissappointed that a given upgrade didn't give the results you anticipated. As any good racer knows, you can't tell crap if you don't have a baseline. Good luck
Old Apr 16, 2002 | 07:42 AM
Axoid's Avatar
Car: 92 Camaro RS
Transmission: T5 manual
I'll assume that you have a LO3, Edelbrock is to only company that I know of that makes a strut tower brace for TBI/Carbs. This brace may not work if you convert to Tuned Port.
Also check the rules of what ever racing your going to do, since some classed may ban certain parts.
Old Apr 16, 2002 | 10:12 AM
Cool thanks, what are the best companys to buy my suspension from??? your help is very appreciated
Old Apr 16, 2002 | 10:20 AM
racereno's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock
Well let's start off with... what do you want to do with it?
Old Apr 16, 2002 | 03:13 PM
well would like to repplace strut tower brace and sub frame connecctors i guess, really not , also what is a wonderbra? I guess just basically my whole suspension, would be nice but I just wanted inputs as to see what I will get.
Old Apr 16, 2002 | 03:18 PM
racereno's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock
Sorry, let me rephrase my question. Do you want to drag, autocross, road race, or just generally run the roads?
Old Apr 16, 2002 | 05:48 PM
well it will be an everyday car and I know I will be taking it to the track , so i guess street/road racing
Old Apr 16, 2002 | 07:04 PM
Jza's Avatar
Jza
... nevermind.
Old Apr 17, 2002 | 06:40 AM
racereno's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock
Then you should do well with a good set of springs and shocks, followed by the stb and sfc.
Old Apr 17, 2002 | 07:42 AM
Axoid's Avatar
Car: 92 Camaro RS
I would also suggest good brake pads, Hawk HPS or the like.
A "wonder bar" is a brace that bolts between the frame and front sway bar. It renforces the area around the streering box.
Old Apr 19, 2002 | 09:48 AM
oops barely realized that i put wonderbra I did mean to put wonder bar I just didn't realize what i was typing
Old Apr 19, 2002 | 03:21 PM
Ok I have decided I will go for the strut tower bar and sub frame conecctors, what brand Edlebrock ??? or something else. anyone have thier pics of theirs, and how much they paid?Please help
Old Apr 19, 2002 | 03:34 PM
by the way i have a stock 305 TBI
Old Apr 19, 2002 | 03:53 PM
racereno's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock
Good decision, go with the Edelbrock stb.
Old Apr 19, 2002 | 04:42 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
I would recommend it in this order....
"Wonderbar" a.k.a. Global West Steering Box Brace $47 (www.yearone.com)
then some high rated tires if you can afford them (I like the
Kuhmo Supra 712s @ P245/50ZR-16) $100/ea
KYB GR-2 struts and Gas-a-Just shocks (p/n 236001/5562) $156
Edelbrock Strut Tower Brace (p/n 5227) $130
Spohn Lower Control Arms $105 w/ Spohn LCA Relocation Brackets $65
Spohn Panhard Bar $85
then get Spohn's Sub Frame Connector (gloss black) $200
Of course your best bet is to fix anything that's broke first. If you want to lower your car then most people would recommend the Eibach kits for like $250 or something like that......also, some people would recommend getting the adjustable LCAs and Panhard Bar, but unless you're doing competition or serious road racing, I would say save your money; especially since it's a daily driver (like mine ) And finally, the reason I put the SFC last is because when you do your exhaust system, it just makes it easier on the guys working on your car to do it all at that same time. Hope this helps.....
Oh yeah, some might suggest getting Lakewood LCAs for like $20 less, but I'm a firm believer in Spohn's quality and I doubt anyone would contest that.
Old Apr 22, 2002 | 09:48 PM
thanks I think I will follow this order thanks GUnny Highway
Old Apr 22, 2002 | 10:17 PM
HrdRockA4305's Avatar
That order sounds good to me!
I'm hoping to do the SFCS and STB this summer, and replace the struts cause I think they're getting worn.
Old Apr 22, 2002 | 10:23 PM
racereno's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock
Sorry guys I'm still not sold on the wonderbar for later thirdgens. I guess the name applies here because I wonder what good it does. Are we saying the sway bar bushing/steering box area is weak on all thirdgens or WAS weak in the pre-stb/sfc years? Just wondering...anyway good plan that I think you'll be pleased with m_o_s.
Old Apr 22, 2002 | 10:25 PM
racereno's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock
BTW, if you lower your F-body, an adjustable Panhard bar MAY be neccessary.
Old Apr 23, 2002 | 11:45 AM
Car: 91 RS
Engine: 350 TBI
Now that is true....if you lower your car, the adjustable panhard is very important for regaining your center.....and most would suggest getting the adjustable LCAs as well if it's lowered.
As far as the "wonderbar" goes; it is definately worth it. I noticed a dramatic increase in the tightness of my front end. And yes the steering box area is a profound weakness on the 3rd gens....the frames on our cars twist and flex soooooo much. There's a reason that the IROCs and WS-6s came with them...because they work better than the stock setup.
LT1Formula
Oct 8, 2015 08:34 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
