can someone help with this problem ?
Old Apr 17, 2002 | 03:39 AM
XonyaZ28's Avatar
Ok before i drop the v8 in i am going to drive the v6 a little longer(bear with the 130 hp) and tighten up the suspension........
*problem**
When i am driving along and i hit 3rd gear and 4th gear my car begins to sway back and forth from side to side(this is coming from the front area) but it stops when i downshift(when my foot is on the clutch that is) and wont start again until i hit 3rd going into 4th gear..there is also alot of free play in my steering wheel. Now i was told that it may be my idelarm
is this true ??
and how can i fix this ? has anyone went through this,and has fixed it ?
thanks in advance !! ~
Xonya~
Old Apr 17, 2002 | 06:21 AM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
Transmission: 5 speed
Yes, ...
... it could be the idler arm or a worn steering box or a centerlink.
Sounds like a front end rebuild is in order before anything bigger goes in the engine compartment.
Old Apr 17, 2002 | 08:05 AM
Buck268's Avatar
yeah, sounds like either a idler arm or a centerlink. My idler arm was not good, but my centerlink was shot, i replaced both, put a wonderbar on, and threw some polybushings on my endlinks (well, all new endlinks). Car must have been 100 times tighter afte I was done. Only thing to watch out for is when you replace the centerlink, the studs that you bolt the idler and pitman arms to spin pretty easy... It's a real PITA to get em tight enough to fit the cotter pin through... BTW, I bought mine from NAPA, and am very satisfied with both the product, and the knowledge of thier salesmen.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
