rear disc tech. question
Old Apr 17, 2002 | 03:12 PM
PAformula's Avatar
I have a '89 Formula 350 w/ rear disc brake and I would like to know how can I find out if my rear brakes are functioning like they should. I know they are working cuz they will slow the driveline down if you test them with the tires off the ground. Is this an accurate test? Should the brakes stop the axle & tires from turning when off the ground?
thanks
Old Apr 17, 2002 | 03:30 PM
Steve89GTA's Avatar
I've been trying to fix my damn e-brake on my 89 forever. I'm giving up and getting some rebuilt calipers and new cables. POS
Sorry, a little vent session.
Old Apr 17, 2002 | 06:51 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
If your brakes don't hae enough power to stop your wheels from turning with it off the ground i doubt it will do much for ya on the road. Do a search for rear brake fix and there should be about a gazilion threads that should help you. I say either your calipers are the older style and need the recall kit or you just need to do the proportioning valve mod. Take a look around you'll see what i'm talking about.
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Jan 19, 2016 12:21 PM
redmaroz
Aug 16, 2015 11:40 PM
