Boxing rear LCA's and Panhard bar
Old Apr 21, 2002 | 11:39 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
I am getting a MIG welder in a few weeks and I wanted to strengthen my LCA's and Panhard Bar. I was thinking of buying new bushings from jegs for $38 and then welding a peace of steel along the bottom of the LCA's and Panhard bar. Is this a good idea? Anything else I can do?
Old Apr 21, 2002 | 04:58 PM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
Be careful not to warp the panhard rod when welding it. I've seen them that look like a long bow.
Might be a good time to buy or fabricate subframe connectors.
Old Apr 21, 2002 | 05:01 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
How do you prevent the Panhard bar from bowing when you weld it?
Old Apr 21, 2002 | 05:06 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Just don't weld a long bead. First spot weld it maybe 8 spots per side to keep it all straight before you really put the heat to it. Then just stitch weld it, little sections at a time, alternate from one side and one end to the other- maybe weld like a 2" bead, then switch. This gives the bar time to cool and retain it's temper.
Old Apr 21, 2002 | 06:14 PM
pianiy's Avatar
Its not a bad idea at all, its what SLP does actually and resells the panhard bars and LCA's back to us. Check it out on their site, all they are is the stock units with 1/8" flat stock welded to the bottoms. I got a chance to take a look at a set yesterday at SLP Day at E-town and they did indeed stitch weld it like IHI said.
My suggestion would be to get a thick piece of flat metal or a strong worktable top and vice grip the panhard rod to it on both ends to keep it from warping when you weld it. Do just like IHI said, spot weld the ends, first, then the middle, alternate sides and stitch weld it, like 1" weld with a 1" space in between or you could even go farther apart. Keep the welds light, the material's thin and you don't want to go through it. Another good tip would be to heat the whole bar up with an oxy/acetalene or propane torch just before you start welding so the bar doesn't get "shocked" by the sudden heat change.
1992rs/ss
Jan 31, 2025 05:10 PM
customblackbird
Aug 15, 2021 10:16 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
NBrehm
Aug 5, 2015 07:57 PM
