help w/ noise
Old Apr 23, 2002 | 06:51 PM
willdog666's Avatar
Car: 1988 camaro sc
Engine: 350 tbi swap
Axle/Gears: posi 3:23 swap
help w/ noise
ok, if i push the side of my car(parked) it sounds like the rear end is singing to me. it lets out a couple of loud clangy squeaks then stops when it stops moving. it seems to ride bumpier too. sounds like my rear is loose or something, it seems to have too much movement from side to side. what's the best to cure this, panhard rod?, control arms?, bushings?, i do have new shocks. just wondering what this is and how to cure it.
Old Apr 23, 2002 | 08:19 PM
pianiy's Avatar
Sounds like you may have a bad bushing in one of your suspension components or needs to be lubed. I'd see about greasing any fittings you can find (although I don't think there are many if any) first before you go through replacing parts that are working just fine.
Old Apr 25, 2002 | 02:48 PM
RGZWS6's Avatar
Sounds like a shock went south.....or your muffler mounts have broken
db057
Jan 10, 2020 08:55 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
Nighthawkf-117
Sep 24, 2015 02:47 PM
Randomtask2
Sep 7, 2015 05:06 PM
