planning on boxing LCA's what thickness steel should I use
Subscribe
Apr 29, 2002 | 04:27 PM
I was planning on boxing my panhard bar and LCA's as a temperary improvement till I get the money to purchase an aftermarket set. I was thinking of going with 1/16" thick steel to weld to them, would this be adequate, I was also thinking about going with 1/8" but I don't want these things to weigh a ton. What do you guys think I should go with?
Reply 0
Apr 29, 2002 | 06:21 PM
I would say as thick as the existing metal should be sufficient. Although 1/16 and thicker will give you a good improvement over stock.
Reply 0
Apr 29, 2002 | 08:02 PM
SLP sells stock production control arms and panhard bars that have been boxed with 1/8" steel and poly bushed.
Reply 0
Apr 30, 2002 | 06:03 AM
I used the strips of metal they sell at lowes. They are the exact thickness and width you need.
Reply 0
Apr 30, 2002 | 10:07 AM
I'd say use 1/8 or 3/16. the wieght difference on a ~foot long piece isn't going to be much.
Reply 0
Apr 30, 2002 | 12:56 PM
Is there anyway to stop the thing from rusting away inside? Or will that take 100 years to happen? Just wondering; I've wanted to box mine for a long time, but I always wondered what happens to that rust. Plus, there'd be no way to coat the inside of the weld... well, unless I hunt down that weld-thru coating...
Reply 0
Apr 30, 2002 | 03:52 PM
Tom P,
Yes just coat it with weld through primer any jobber carries it.
For the rest of you guys, how much of an improvement will I see from boxing them? Will it be noticable or barely at all?
Reply 0
Apr 30, 2002 | 05:05 PM
Thanks! Maybe the same place will be able to get me a CO2/Argon bottle for my LE MIG... right now it's set up for FCAW, I bought the GMAW conversion kit, but never bothered to hunt down a bottle... haha... okay, thanks!
Reply 0
Apr 30, 2002 | 10:12 PM
Reply 0
May 1, 2002 | 06:19 AM
Quote:
Originally posted by grafx
. . . For the rest of you guys, how much of an improvement will I see from boxing them? Will it be noticable or barely at all?
I doubt that you'll ever notice. A basically stock 305 on street tires doesn't need the additional strength or buckling resistance, especially with a torque arm/PHB suspension (as opposed to the 4-link G-body or Mustang arrangements).
For handling, the unboxed LCA's are actually slightly better given identical bushing material. The torsional flex relieves a little of the bind.
Norm
Reply 0
Subscribe
