couple questions
Old Apr 30, 2002 | 01:14 AM
89Irocker's Avatar
couple questions
I am looking for a strut tower brace and sub frame connectors for my car and am wondering who makes good ones for a reasonable price? I want a STB that will bolt right up and weld in SFC's. Car is in sig. thanks for advise.
Old Apr 30, 2002 | 01:40 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
there are several options.
there is the 3 point STB, that is made by edelbrock (i like the 3 point design personaly, but i know many people who really like the 2 points they have) and the 2 points are made by hotchis and bmr.
for SFC's i would either get spohn (when he starts making them again soon) or kenny brown.
but realisticly any STB or weld in SFC's will make a huge diffrence in your car
Old Apr 30, 2002 | 11:44 AM
89Irocker's Avatar
do you have to do any welding for the edelbrock brace?
Old Apr 30, 2002 | 12:44 PM
Momar's Avatar
I have not done it myself, but I believe that you just have to drill holes and put bolts in.
Old Apr 30, 2002 | 02:52 PM
Dewey316's Avatar
Car: 1990 Camaro RS
i am 99% sure that none of the ones i listed need welding, i have the edelbrock (for TBI/carb) and i had to drill 6 holes, and that was it.
Old Apr 30, 2002 | 07:26 PM
89Irocker's Avatar
how hard is it to install a panhard rod?
Old Apr 30, 2002 | 09:01 PM
Momar's Avatar
It is easy to install a panhard rod. The main thing needed is some strength because these bolts are rated at 93 ft lbs of torque and have usually been on there a long time. You just need to have the car up where you can get under in, then I would support the rear end so it is not as likely to move around on you and take out the two through bolts and bolt the other panhard rod to the right torque. I assume you actually mean panhard rod and not still the strut tower brace right?
Ben
Old Apr 30, 2002 | 09:18 PM
89Irocker's Avatar
yes, I'm talking about the panhard rod now. Thanks
Frozer!!!
Jan 19, 2024 04:55 PM
chazman
Aug 28, 2018 03:25 PM
Cleotiz
Jan 6, 2018 08:56 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
