View Poll Results: Should I go tubular or stock?
PA Tubular
90.91%
Stock
9.09%
Voters: 11. You may not vote on this poll
K-Member: Tubular vs Stock
Old Apr 30, 2002 | 07:16 PM
mult68's Avatar
Car: 1992 Chevy Camaro RS
Engine: 305 TBI
Ive searched the archives...and Im still uncertain of which to go with. I just got my hands on a 92 Hardtop RS with no engine/tranny...im building it up with a 383 Miniram...it wont be my daily driver....but I will be driving it on the street...probably more so than on the track (drag and autocrossing). I looked under the car....and the k-member is crunched BAD. So im debating on whether I should spend the money on a PA Tubular k-member...or just get a regular stock one. I want to go ahead and buy it soon so it'll be ready for the engine to be dropped in. Any suggestions?
Old Apr 30, 2002 | 09:58 PM
Morepower383's Avatar
Get the PA tubular K-Member it's totally worth the investment....you can loose over 100lbs and you can also switch over to a rack and pinion steering set up. Remember WEIGHT=HORSEPOWER....Every 100lbs you take out of your car is worth a tenth of a sec in 1/4 mile times
Old Apr 30, 2002 | 11:18 PM
mult68's Avatar
Engine: 305 TBI
Will I gain ground clearance as well? Whenever I scape the bottom its either the k-member or the cat.....and if I do gain clearance...will I have more of a chance of hitting the oil pan? Texas streets SUCK. Some recommended I weld a piece of steel from the k-member out extended past the oil pan to keep it from hitting. Think this might be a good idea?
Old May 1, 2002 | 09:13 AM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
Is the tubular version strong enough to handle daily driving?
Old May 2, 2002 | 02:38 PM
camaro6spd's Avatar
you can always weld up a skid plate for the oil pan and anyother important low hanging items.
Old May 2, 2002 | 09:41 PM
...Well these K-members are suppose to be able to handle the rigors of road racing so they should hold up, but of course bumpy roads and potholes don't help...I have a lot of friends who have daily driven Mustangs with tubular k-frames in them and haven't had any problem at all...As for the Camaro well I drive my Camaro almost everyday and i'm planning to put the k-member in so i'll let ya know when I put it in
Old May 3, 2002 | 09:59 AM
camaro6spd's Avatar
just remember, the stock one is stronger, it will hold up better if something happens...like being run off the road....on street driven cars it does not matter how good of a driver your, other are not, i prefer for my convertible strength over weight, i don't plan on racing it, it is a street driven cruzn' car... so i am trying to make it as ridged and stong as possible to a certain extent...No i am not gonna add 500 lbs of steel but you get what i am sayn.
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Scamo-2.8
Dec 5, 2015 09:16 PM
Genopsyde
Oct 7, 2015 08:35 PM
lt1z350
Aug 28, 2015 05:57 AM
