IROC skidpad test?
Old May 1, 2002 | 09:01 PM
Trent257's Avatar
IROC skidpad test?
what would a 90 iroc-z pull on the skidpad? ive head around .90-.92. what can i do to improve this?
Old May 1, 2002 | 09:14 PM
jayg's Avatar
Car: 1992 Formula 350
The best thing you can do is use very sticky tires. Set up the suspension to be as neutral as possible. Negative camber in the front -1 to -2 degrees with maybe a 0 to 1/16 toe out. You do not need a larger rear sway bay. They cause a lot of excessive oversteer. Spherical bearings in all bushings. Ideally, you would run on a skidpad and measure tire temps from inside to out and the temp would be similar if you had the correct setup, making adjustments to pressure and negative camber for any corrections. Sticky tires would be the a good start though.
Derick15
Sep 17, 2016 05:28 PM
Jae992
Aug 27, 2015 09:07 AM
mustangman65_79
Aug 11, 2015 03:17 PM
